Square Stem Question "Click" to Login or Register
How does the crown attach to this square stem? Does it take a special case? Thanks...Paul
Posts: 122 | Location: Baltimore, Maryland in the USA | Registered: February 25, 2011
IHC Member 1342
Hi Paul - Yes - the stem has a square opening.
I am at work right now, so I can not post a picture, but maybe one of the other experts can get a pic for you. Once you see one - you will know what to look for when selecting a new case for it.
Marc Micale
Posts: 144 | Location: Milwaukee, Wisconsin in the USA | Registered: September 16, 2009
Hey Paul, If that is an Elgin convertible,then I think yes it does take a special case.
Cecil: I do not have the movement. It is one i was going to buy. I have never seen one like this. Is that type of case hard to find? Thanks...Paul
Picture of Jerry King
Paul what is the serial number of the movement...? I do not believe it is a convertible because of the location of the lever set arm and there is obviously no seconds chapter....but the s/n would help....
jerry: the s/n is 2375589. I never noticed that it did not have a seconds chapter. Hope this infor helps. Thanks...Paul
Paul,
Info from the Elgin sight makes it model 1 6s 11 jewels hunter movement.
Seconds chapter was removed to make it fit an open face case.
Serial Number---SN Range-RunQty-Name-Year-grade-size-code----jewels Adj/reg/etc.
--2375589-------2370001---10000------1886--94----6s--h3g1l-----11j
grade-total-----runs--first yr--last yr--class----size--code---jewels Adj/name
-94---273000---52-----1882----1891----52-----6---h3g1l----11j
Steve
Paul, I don't know how much the auction is for this movement, but, unless you want something to mess around with, I would stay away from it....
The case will not be an easy find, a nice dial, assuming Steven is correct is another easter egg hunt plus the seconds hand will need to be refitted....Just too much going against it....
That's just my opinion....
Steven: Thanks for the info.
Jerry:the movement is only $25.00, but if it's going to be that hard to find a case i'll keep looking for something else. I have a question. I hope this doesn't sound stupid but what is "convertible" and can an open face be put into a hunter case and vise versa? Thanks...Paul
Hey Guys, Something just ain't right here. Wouldn't the set lever on a hunter movement be by the 5. This one is by the 2,where open face movements are. Also what difference does it make if it has a second hand or not when fitting it to a case? Only thing I can figure is,the dial is switched,and the second hand pinion was removed because they couldn't find the proper dial to make the conversion.
Paul, A convertible movement is one that can be switched from hunting case to open face case and back depending I guess on which the owner wants.
Cecil: If a movement is not a convertible what is the difference in the two, Hunter vs Open face. Is it the front plate diameter? Thanks..Paul
HI Guys,
All 6s elgin movements were made hunter style. In order to put them in an open face case,and have the 12 at the stem and the set lever at 2, faces were made with no seconds chapter. On a hunter face, the stem is at three, so in an open face case you would get a "sidewinder".
As for cases, most were gold, so they are going fast.
Hope this helps
Steve
Paul, this is the movement from my 16s Elgin convertible.
Like Cecil said, the movement has a secondary winding arbor at the 3:00 position, making it possible for this watch to fit either case style and still have the dial alligned corrctly.
The black arrow is the winding arbor for open-face and the red arrow is for hunter configuration. The blue arrow shows the 4th wheel, the pinion of which holds the seconds hand.
Dial and caseback:
Ok, so if i understand this correctly an open face movement can be mounted in a hunter case but the winding arbor will not be in the right place but it will fit into the case. The same with a hunter movement, it can be mounted in an open face case and it will fit with the arbor in the wrong place. Am I right??? I hope so...Paul
Well, I see where I went wrong. I hadn't noticed it was a 6 size movement. My mind is stuck in the 16-18 size. It is pretty common for those small movements to not have a second hand,and by simply changing the dial it can be either hunter or open cased.
Paul,the hunting movements are different from the open face movement in the placing of the wheels in the gear train. In hunting movements the set lever is at 5 o'clock,and in open face movements the set lever is at 2 o'clock. Except in the case of the one you are looking at,which has had the dial changed. If you think about it,hunting movements are meant to be viewed with the crown at 3 0'clock,and open face are meant to be viewed with the crown at 12 o'clock
Yes the movements will fit either case.
Cecil: A change of dial meaning complete change or a rotation it the mounting pins will allign?
Two things, first the Elgin Convertible is the only movement that was actually designed so that it could be changed or "converted" to be either a Hunter or Open-Face configuration. Whether it is configured as a Hunter or Open-Face the setting lever is at 27.5 minutes. The position of the winding mechanism can be moved making them of great interest to collectors, in fact recently I have become very interested in them. Smile In addition to what Eric provided above, here is a more detailed technical explanation...
CLICK FOR: Elgin Convertible Conversion Tutorial
Jerry King and I recently determined that some of the last Elgin Convertibles manufactured in the 1890s could be fitted to positive-stem cases, unlike earlier examples which required the difficult-to-find negative-stem cases and looked a lot like the topic movement.
Secondly, as Stephen previously determined, the 6-size movement in question was originally a Hunter that was factory modified from Hunter to Open-Face by removing the 4th wheel pinion. That eliminated the seconds hand, they then installed a dial made without a seconds register and the feet in different positions so that 12 rather than 3 was at the pendant position.
This was a common marketing tactic that allowed the watch companies to sell off leftover inventory. It was done with leftover movements after the particular Hunter movements were no longer in fashion, there are numerous examples. Whenever you see the absence of a seconds register that is a clue that what I described above has been done to the movement.
