Any Rockford Experts? Early Rockford Marked "EXTRA"Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Have you ever seen an early Rockford marked "Extra"? This is a model 4, Grade 52? lever set stem wind ball diamond? damaskeening Neat beautiful porcelain dial signed just Rockford not RWC like most This is 1884 I believe It's a 13 Jewel...what did extra mean? It's a customers watch, any idea of value? rarity? I can't come up with any info on it...does anyone know about this watch? Thanks in advance | |||
As that serial number Model 4 movment was in the early pre-grade assigned Rockfords, I am speculating Rockford marked "Extra' on it to show the added quality of the watch. The Square type damaskeening later did denote some of the higher grades. | |||
I've seen this pattern before. I'm puzzled - I can see the square center arbor, so is this watch pendant-wind, key-set? Or can the time be set with the crown, with the square canon pinion being a transitional thing? | ||||
I have an older 18s KW Rockford that is stamped "extra" on the mainspring barrel plate ![]() | ||||
I am not sure this relates but on watch cases it meant a better quality case for most case makers and I have had, Years ago, a Rockford transitional hunter that was marked extra and at the time I was told by the elderly seller that the extra meant it was also stem wound. Deacon | |||
Oh My regards, bb | ||||
Youth is my excuse Buster. Deacon | |||
Very permissible Deacon, To be young, dumb, and full of rum What would we give regards, bb | ||||
