Page 1 2
I Was Offered A Fusee For $20 "Click" to Login or Register
I Was Offered A Fusee For $20 ...
... so I bought it. It didn't run, it was wedged in the case, the hands were missing, and the bow was broken - but for $20, who cares?
I've never owned a fusee, and had certainly never taken one apart. As I started carefully breaking it down I realized the thing was actually capable of running. The balance pivots were good, the pallets were intact, and the escape teeth weren't worn or missing:
The insanely delicate chain was intact, and the internally ratcheting fusee cone worked:
The plates were in great condition, all the pillars were there, and the taper pin holes weren't blown out.
Could the '86 mean 1786?
The provenance was all over the dial side of the pillar plate.
"R Kline 1861":
"Rep'd by N Barns Jan 1851":
The earliest date on the watch is "E W Baker 1841":
Not only did I get it back together, but it's running and keeping time.
I had to blue several screws, and I replaced all the brass taper pins.
I have no idea if a hack feature was common on fusees, but this example has one. It's the lever sticking out in the left-hand corner of the photo.
A side view showing the barrel, fusee, and that ridiculously delicate chain:
The opposite side view showing the contrate wheel meshing with the escape wheel:
The movement hinges into the inner case along with the swingout crystal bezel. Then the entire thing fits into a clamshell outer case.
The bow was a challenge. It was worn thin and broken in half. After thinking about it, I made a two-pin jig to hold it while I soldered it. I used solid lead/tin solder, not rosin-core. Then I filed it as close as I could back into shape and polished it. I turned a new brass pin for it, since the old one was deformed and rusted to the point were I had to cut it out. Not perfect, but at least it stands up on its own.
This was definitely worth the effort. I have tremendous respect for the craftsmen of centuries ago. Remember, I've only been working on my own stuff for a couple of years now. I could not have done this were it not for the help of members like Roger Nolfe and Chris Abell and the knowledge gained from this club, reading the posts, and taking the time to research projects like these.
Here is the final work, all cased up and running very well.
Can anyone help me with a set of hands? I have absolutely no square-arbor hands, gold or blue.
beautiful work Eric
Posts: 241 | Location: Ponca City, Oklahoma in the USA | Registered: May 19, 2011
walker has good value, well worth the effort. Nice to know who I can send all my fusee repairs to!
PS...SENT YOU AN EMAIL?? NO REPLY?
Posts: 5101 | Location: Buffalo, New York in the USA | Registered: November 11, 2009
Picture of Gary E. Foster
Eric, that's a great restoration, how long did it take, congratulations.
Gary
Picture of Eugene Buffard
Eric I will send you a photo of the hands you can pick from. Tomorrow - I would think this watch should have older hands.
Posts: 3328 | Location: Illinois in the USA | Registered: July 06, 2010
Picture of Peter Kaszubski
Great work Eric
and here is my link why you should be proud of your work.
"Make sure the watch you accumulate will leave your hands in better condition or make sure it gets in hands of someone who can improve and correctly restore it"
https://ihc185.infopop.cc/eve/f...6047761/m/2103934977
Bravo to Eric.
Well done Eric ; Kudos!
The '86' on the movement is the serial# of the watch. It was made by Joseph Walker of Workington ; 1828 - 1869; watchmaker and jeweler (Watchmakers & Clockmakers of the world p243). This watch was made in his early years (1830-1835).
Whenever possible take golden hands to finish this beautiful restoration job.
The case should have some hallmarks I would like to see.
Gerald
Thanks, boys. Smile
Gary, it took me a week or so, and there's still the hands to contend with.
Gerald, danke for identifying this watchmaker. 1786 seemed a little early, since it has a seconds hand. I take it that Joseph Walker was British, and Workington is someplace in England?
Here are the outer case hallmarks, with Mr N Barns showing up again:
And the inner shell trademark:
The case is hallmarked : Sterling silver, chester, 1837, duty mark; no clue on the makers mark.
Workington is a city at the north-western coast of england; cumbria.
Gerald
Site Administrator
Picture of Phillip Sanchez
Eric, wonderful stuff, a great mechanic, all of those tiny screws.
IHC Member 163
Picture of Mark Cross
Absolutely amazing! Eek
FANTASTIC job!!! Smile
HIGH regards! Mark
Posts: 3840 | Location: Estill Springs, Tennessee, USA | Registered: December 02, 2002
Nice job Eric. Fusee's can be a lot of fun to work on.
Here are some photos
2
You know you can make a square hole out of a round hole.
I would use this style to match the hours-hand - given that size and colour matches.
Gerald, I'm assuming that the hour hand is correct because it was till on the watch, even though it looks a little small to my eye. What is Chester (in the case markings)?
How about it, Gene? The minute hand needs to be about 22 or 23 mm long from the tip to the center of the arbor hole, and that square hole needs to be about 1.3 mm to a side.
This hour hand is about 14.5 mm long and could be about 16 or 17 to reach the Roman numerals. The ID of the arbor hole should be no bigger than 2.75 mm.
Now I need a seconds hand, about 8 or 9 mm long, on a pivot diameter of about .35 mm.
Eric
Chester is the city in north-west england where the watch case was assayed and hallmarked. (Other assay-offices were located in London, Birmingham, Exeter, Newcastle, Sheffield .. ) Each assay office had his own city mark (Chester's was 3 wheatsheafes) and a specific date-letter code. For Chester the 'T' in this given shield indicates the year 1837.
For the hands: I would think the hour hand is correct.
Please have a look at the center mark. What are the two letters indicating the casemaker ?
Gerald
It looks to be TA in the center of the outer case, Gerald. The three sheaves of wheat are on the right?
If the Lion of England is at the top, then what symbol is on the left?
Inner case marks:
