Elgin convertible with R in serial number "Click" to Login or Register
IHC Member 3010
posted April 18, 2023 13:55
Does anyone know what the "R" is for in an Elgin Convertible grade 50 serial number? I have several grade 50's but none have an "R".
R3507256
Thank you,
Posts: 91 | Location: Maryland in the USA | Registered: October 22, 2019
IHC Member 1555
posted April 28, 2023 23:53
Hi Larry,
I have a question for you about the Elgin, is the "R" only on the dial plate serial or is it marked on other pieces of the watch that has serial numbers, i.e. such as the Barrel-bridge, back-plate and the like, thanks?
kind regards,
bila
IHC Member 3010
posted May 01, 2023 04:57
Bila,
It is marked on the barrel bridge the back plate and the like.
IHC Member 1555
posted May 01, 2023 18:42
Thanks Larry for the response, below you will see another marked with the "R", it is only marked on the dial plate. THis belongs to a good friend, he is on another Forum and has given me permission to post his photosSmile
Both he and I are as curious as you are to why the "R" before the serial number???
IHC Member 1555
posted May 01, 2023 18:43
Here is the back-plate view.
IHC Member 3010
posted May 02, 2023 07:40
bila,
It is interesting that it seems to be from the same run both 3507XXX.
IHC Member 1555
posted May 02, 2023 08:16
Yes Larry, the same run, I have not looked to see what size run this was. Maybe a 1000, I wonder if all were marked with the R?
Yours also marked on the barrel bridge as well, yet my Friends one only on the dial plate. Seems an odd thing to do by the Company???
IHC Member 3010
posted May 02, 2023 10:21
Bila,
looks like elgin used letters for the first numbers over one million. For instance the R is seen in row 3x and column .5. This would indicate 35. This is seen under the balance cock on mine R07256.
posted May 02, 2023 10:59
Larry,
Here's another that fits your grid.
I've seen others with letters and symbols at the start of the number, but I don't have photos of them.
Steve
