Hairlines - Which Dials Are More Susceptible? "Click" to Login or Register
Picture of Stephanie O'Neil
posted October 01, 2003 19:11
We have talked about your opinions of hairlines. Cool Thread is still open for more discussion.
Phil D said he thought Illinois Sante Fe Specials and Illinois Burlington seem to have fragile dials, possibly thinner procelain. Roll Eyes
Charlie said with 18 Size Bunn Specials, usually a hairline is found at the sub-second dial. Roll Eyes I recently read there is a clear coat of enamel over fancy colored dials, and most all of them have developed little hairline cracks as a result. Roll Eyes
Kevin stated using improper tools to remove dials coult result in hairlines. Roll Eyes
It seems colored fancy dials are most susceptible to hairlines. Maybe I notice them more so as I'm always on a search for them and see the hairlines. Roll Eyes Eek
Which dials are more susceptible to hairlines and why? Confused
Stephanie O'Neil
NAWCC Member 143979
Posts: 1419 | Location: New Orleans, Louisiana USA | Registered: April 01, 2003
Watch Repair Expert
posted October 01, 2003 20:03
I rather suspect we encounter hairlines more frequently on desirable dials primarily because the ones without the hairlines have found their way into well-established collections already, and seldom hit the open market anymore. Essentially, that leaves the rest of us circulating the less desirable ones.
That said, it seems to me that Rockford Wind Indicator dials are more problematic than any other that readily come to mind. Since I like those watches, I tend to notice them, and of the 40 or 50 I've seen in my life, I don't think I've seen more than two or three with perfect dials. Of course, there again, my observations are probably biased because the watches I've seen have been in the market, and may not necessarily be representative of all existing examples.
Remember, the conclusions we all draw today come from observing the watches that are currently in circulation. We really have no idea what sort of stuff exists in private collections, and it's possible that the stuff that's been removed from the market today, may actually be more prevalent than the stuff that's left.
Steve Maddox
President, NAWCC Chapter #62
North Little Rock, Arkansas
IHC Charter Member 49
posted October 01, 2003 21:01
Steve has a very good point - the more collected a given watch model is, the more likely the perfect dials are already taken.
Those switchers at it again !
Charlie
Posts: 719 | Registered: December 15, 2002
posted October 02, 2003 07:41
O pinion again...
ALL dials are susceptible......
I agree with Steve on the Rockford indicator dials....
Rockford dials in general seem to be found with hairlines.....
Good points are made on the "perfect" squirreled away dials....
Life Achievement
Military Expert
Picture of Greg Crockett
posted October 02, 2003 10:53
this squirrel will not give up his perfect dials!”
Razz
Posts: 2049 | Location: East Lansing, Michigan USA | Registered: November 24, 2002
IHC Member 155
Bulova Watchmaker
Picture of Rich Kuhn
posted October 02, 2003 11:15
I agree with just about everything said above. The fancy dails cannot be cleaned to hide the hairlines so they do stand out more if there is a problem.
The hunt for a perfect dial will always go on and on
Rich Kuhn
NAWCC 128623
IHC Member 155
posted October 02, 2003 13:10
Some are just thinner than others. On the left, Hampden. This seems a typical thickness of most dials I've looked at. On the right, Seth Thomas. Very thin. I don't know if this would have any effect though.
IHC Member 25
IHC Life Member (L6)
Posts: 661 | Location: Wisconsin in the U.S.A. | Registered: December 07, 2002
posted October 02, 2003 13:13
faces
IHC Member 25
posted October 02, 2003 16:09
WOW!!!
Larry, you really made that one clear, the S-T in your picture looks positively fragile! Rich Kuhn's comment about our being unable to "soak-out" hairlines in colored dials is one I had not previously considered. Rich is right, there's no hiding the flaws in fancy dials! Another point on colored dials is the multiple trips to the oven for the layers of decoration to be built-up may also cause them to be more brittle.
Charlie's comment on "switchers" brings to mind something I find interesting. Recently some of us observed quite a uproar regarding re-casing of watch movements. I was struck by the fact those who so vociferously and even viciously decry re-casing are the same ones who brag the loudest about having large collections of dials.
Steve, those Rockford Indicator dials are among the all-time greats... and of course the RG 655 movement's no slouch either!
Picture of Stu Goldstein
posted October 03, 2003 13:47
Larry’s photos are really interesting! Not only is the Hampden thicker; its edge is so much more finely finished – smoothed and chamfered. How did they do it? Do Hamiltons, Walthams, Elgins look like this Hampden? Is there a difference among grades within a given maker? This is good stuff!
Posts: 355 | Location: Northern Idaho in the U.S.A. | Registered: November 26, 2002
Picture of Wayne C. Anderson
posted October 03, 2003 17:37
Waltham painted dial edge.
Painted Dial
posted October 03, 2003 19:37
Waltham dial porcelain.
Waltham Dial
Watch Repair Expert
posted October 04, 2003 03:38
When enamel is hot, it essentially becomes a viscous liquid, with all the flow properties pertaining thereto. When the liquid encounters a surface irregularity (such as the edge of the dial or a dial foot), surface tension draws the enamel upward or downward for a short distance. I don't imagine many people will have the foggiest idea what I'm talking about, but perhaps the sketch below will help explain it.
The copper bases upon which most porcelain dials are fired, are relatively thin. Of the overall thickness of the dial, the copper portion seldom composes more than 10 to 20%. To prevent the enamel from drawing thin near the holes, those are cut last, after the enamel is finished, and to prevent it from drawing thin near the edge, a "lip" is formed around the perimeter. By looking at such a dial from the edge, it's easy to get the impression that the copper is much thicker than it is, but that's only at the edge. Again, the sketch below should be much more explanatory than words.
In figure "A," a cheap dial is shown in cross section. Note how the copper base is flat, and how the enamel has receded near the edge, thereby leaving a thin curved portion at the perimeter. In figure "B," however, the lip around the perimeter of the copper base allows the hot enamel to flow up the edge, thereby taking advantage of the surface tension to create a dial surface that's almost perfectly flat. In figure "C," a hole is shown which was drilled before the dial was fired; again, the enamel has receded from the edges of the hole, thereby leaving a surface that isn't flat. Many porcelain dials on cheap watches (Ingersoll Reliance models, etc.) have this characteristic.
Finally, note how the enamel tends to "gather" around the dial feet; again, this is the result of simple surface tension.
SM
posted October 04, 2003 10:40
Steve am I correct that none of the sketches resembles the profile of Larry’s Hampden? How was it produced?
posted October 04, 2003 12:06
Here is a Waltham dial that I believe matches Figure B in Steve Maddox's drawing. Its an early model 16size dial.
Waltham
Watch Repair Expert
posted October 04, 2003 16:20
Dog -- I honestly don't know how the Hampden dial in Larry's images above was produced, but it's apparent that the perimeter has been "ground" to finished size. That was a common practice, but I don't have a dial like it here that's suitable to be destroyed in order to find out how it was made.
One reason that particular dial thicker than most is probably because it's a "glass enamel" dial, which is essentially a porcelain dial with a clear coat of glass over the top. That's how the metallic crescent-shaped pieces show through, yet are not raised above the dial's surface.
Other reasons some dials are thicker around the edge is due to the various "sunk" sections. Obviously, in order to create a double-sunk dial in which all three sections are level on the back, the outer ring has to be thicker than the center, and the center has to be thicker than the seconds register. It's hard to tell for sure about Larry's ST dial, but it looks like a "pseudo double-sunk" dial, which is essentially just a single-sunk dial with a ground circular part in the middle to create the appearance of being "double-sunk."
Wayne -- The dial in your image does match illustration "B" in the sketch above. If you'll closely examine the chip in the edge near the 21 minute mark, you should be able to see the raised rim of the copper base that I mentioned.
posted October 06, 2003 13:39
Steve M.,
I would think sooner or later (barring heirs lack of interest) those desirable dials in well-established collections will hit the market. Smile Good points you make!
What's in circulation and what's not is a time-frame thing. What's in private collections could very well be hairlines on beautiful watches, pending on collectors standards at the time of purchase.
Charlie,
Thanks
Terry H.,
From reading a number of comments from active collectors here at the site, I would say the same; ALL dials are susceptible.
Greg C,
Go Greg!!! Smile Smile Cool
Rich K.,
I would suppose fancy dials could not be cleaned because of color(fading) & guilding motif & decorations? Confused
Thanks for your comments.
Larry S.,
Interesting to show pics and thickness of dials. Technique in making dials, poured or coated possibly?
Thanks Larry.
Lindell,
Thanks for pointing out that multiple trips to the oven for the layers of decoration built-up can possibly cause brittle dials.
Not to worry, no switching of dials here. There are colored dials and then complete watches with colored dials in my collection that will stay on their designated watch! Wink
Stu,
Wayne C.
Thanks for the comparison in pics.
Steve M.,
Thanks for the detailed explanation with illustrations with regard to porcelain dials. Smile
Stephanie O'Neil
NAWCC Member 143979
