  HELP IDENTIFYGo  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
 WHAT IS GOING ON HERE GOLD TONE 2/3RDS - NOT GILT 22585365 Grade: No. 620 Movement Serial Number:22585365 Estimated Production Year: 1919 Run Quantity: 5000 Size: 16s Jewels: 15j Movement Configuration: Openface Movement Finish: Unknown Model: 1908 Movement Setting: Pendant Plate: 3/4 Plate ![]()  | |||
 WHAT IS THE DEAL WITH THIS? THANKS ANDY ![]()  | ||||
| IHC Vice President Pitfalls Moderator IHC Life Member  |
 Andy, Is the balance bridge supposed to be not gold-flashed or did someone just switch it out? You could check the numbers stamped on the back side to see if it is legit. Best Regards, Ed  | |||
 ed, if I take it out adios watch....I will call dr unselt... what is with the gold flashed?  | ||||
 Andy, Your movement is correct Movement alone 60-80$ Is there a drilled hole on the winding wheel - looks odd  | ||||
 what do you mean by current? correct?  is there any value?  | ||||
 its all good and correct Andy its 2 tone Waltham just not sure of the small hole on windind wheel  | ||||
 TY!  | ||||
| IHC Member 1613 |
 Andy, Your watch looks correct...I have had several over the years...The winding wheel just needs the washer that goes under the screw..I have some at home if you want one let me know and I will send you one on Monday..  | |||
 well, let me ask this....you guys want this bad boy here?  I think the dial has no lines and it is in a 25yr challenge case that is nice, wgf. please let me know, I will do it with no reserve if there is desire. then the washer can go to the winner. Thanks so much Gary!  | ||||
 Andy, Here's a P.S.Bartlett in the same colors.  | ||||
