messing with lathe and heat on some ratchet wheels. ![]() | ||
IHC Life Member![]() |
Peter, It looks to me as the heat effected the teeth more so than the wheel except for the bottom wheel. I often wondered how heat would effect a bent staff. Patrick | |||
IHC Member 1610![]() |
Looks pretty neat Peter. I really like the brownish color. Harry | |||
yeah the brownish looks like amber or good beer in real life hehe. | |||
I heard the the brown and blue colors come from the difference in the heat temp. applied. I don't know if that is true or not. | |||
the brown is from reheating again to blue temp. | |||
another batch ![]() | |||
Nice going peter. I like the one on top. You should experiment with some diamond compounds if you haven't already. After your lathe work, you could start with 5 micron, then go to 2. finishing with 1/2 micron will give you a mirror finish that you could then color with heat. Here's where I've gotten mine in the past: http://www.smg-diamond.com/Compound.html William | |||
Thanks William that was my next step to get mirror finish but could not find the place for the compound. | |||
Cool idea Peter. I used the bluing machine built from specs in one of the posts here to make my ratchet wheels blue. I will say that the mirror finish is critical and that the different temps give you the colors (570 degrees F gives you deep blue). I used multiple grits of sand paper from 800, 1500, 2000, then polished with semichrome with a dremel until I got the mirror finish (will have to look up the diamond compound now ![]() | |||
Nice work Peter! Kindest regards, Serge | |||
Thanks all just experimenting pic of finish watch looks better in life | |||
another one done ![]() | |||
Really nice Peter adds quality to the finish IMHO | ||||
Very nice Peter! | |||
thank you guys. I'm trying my best. | |||
