Opinions on the sangamo special ,23 jewel.. "Click" to Login or Register
Picture of Paul Davis
posted July 03, 2016 14:06
A lot of people think these are suppose to run 60 plus hours, I found in the book from the factory that these should run between 48-55 hours, so I'd like your opinion on how long these are suppose to run, factory wise, not cobled up..thanks
Regards Paul
Paul Davis
Posts: 672 | Location: Missouri in the USA | Registered: May 01, 2015
IHC Member 2134
posted July 03, 2016 14:54
Well, I know that the Bunn Special you COA'd for me will run 48 hours when I forget to wind it.
Mort Denison
Posts: 175 | Location: York, Pennsylvania in the USA | Registered: February 27, 2016
IHC Member 1725
posted July 03, 2016 16:55
Hi Paul,
This is just my take on the subject, in other words my opinion and experience. I don't put a lot of concern on how many hours I can get a watch to run for, and on top of that the watch is going to vary on running time in certain positions. What I do have a big concern for is how good the watch performs in a 24 hour period. Keeping the watch wound at the same time every day every 24 hours or as close as possible keeps the main spring in its peak performance range. I have noticed these watches drop off considerably in time keeping ability the last 12-8 hours of the main spring.
Saying all that I would be happy with 48-55 hours so it would not stop in case I forgot to wind it.
"Just my two cents worth"
Tim
posted July 03, 2016 17:30
I expect the '60' hour feature is just like a 2X4 which is 1 5/8 X 3 5/8 inches, nominal measure. Many years ago when I was using a Hampden 105 to run freight trains it was wound once a day as close to the same time as possible and it never varied out of railroad specs. A 48 hour run with the same performance would have been a bonus, for sure.
Posts: 45 | Location: Maine in the USA | Registered: April 27, 2010
IHC Member 1955
Picture of Michael P. McNamee
posted July 06, 2016 23:16
Hi Paul,
If you check out the IHC Illinois research forum,
https://ihc185.infopop.cc/eve/f...1029912/m/4231069691
you'll see that the 23j Sangamo Specials were produced with 60-hour mainsprings beginning in the mid 1920s. The earliest 60-hour movements, I believe, were not so marked on the movement, but the later ones were. Prior to that, they were standard 48-hour movements. For example, my ca. 1921 SS Model 10 that is pictured on my avatar came before the 60-hour movements were produced.
Posts: 1088 | Location: Minneapolis, Minnesota in the USA | Registered: October 15, 2013
IHC Member 1291
posted July 07, 2016 08:50
Great answer Michael !!
posted July 07, 2016 09:20
Thank you very much Mike for the clarification, I couldnt find that in my books, ...
Paul Davis
IHC Member 1911
posted July 07, 2016 13:43
You can always tell quickly if it is 60hr or not by the balance cock- Early 48 Hour ones have the border on the balance cock- later 60 hour ones do not have a border- easy way to tell at a glance.
Terry Jones
Posts: 84 | Location: Central Illinois in the USA | Registered: December 12, 2013
Administrative Assistant
Picture of Dr. Debbie Irvine
posted July 07, 2016 15:53
In the link that Mike referenced, Lindell posted the following information...
________Note: The 48-Hour Model 10 should stop by number 4167000_______
_____________________________________________________________
________Note: From this point Sangamo Special movements are 60-Hour_____
...and looking at the images he posted you will find "Sixty Hour" spelled out.
Posts: 5541 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
IHC Member 1955
posted July 11, 2016 20:04
Thanks for the compliment, Buster. Coming from you that means an awful lot.
You're welcome, Paul. Illinois watches are one of my favorite to collect, and I've spent a ton of time researching them!
Dr. Debbie's terrific contributions need no further comment from me. Smile
