Opinions on the sangamo special ,23 jewel.. "Click" to Login or Register
Picture of Paul Davis
A lot of people think these are suppose to run 60 plus hours, I found in the book from the factory that these should run between 48-55 hours, so I'd like your opinion on how long these are suppose to run, factory wise, not cobled up..thanks
Regards Paul
Paul Davis
Posts: 672 | Location: Missouri in the USA | Registered: May 01, 2015
IHC Member 2134
Well, I know that the Bunn Special you COA'd for me will run 48 hours when I forget to wind it.
Mort Denison
Posts: 175 | Location: York, Pennsylvania in the USA | Registered: February 27, 2016
IHC Member 1725
Hi Paul,
This is just my take on the subject, in other words my opinion and experience. I don't put a lot of concern on how many hours I can get a watch to run for, and on top of that the watch is going to vary on running time in certain positions. What I do have a big concern for is how good the watch performs in a 24 hour period. Keeping the watch wound at the same time every day every 24 hours or as close as possible keeps the main spring in its peak performance range. I have noticed these watches drop off considerably in time keeping ability the last 12-8 hours of the main spring.
Saying all that I would be happy with 48-55 hours so it would not stop in case I forgot to wind it.
"Just my two cents worth"
Tim
I expect the '60' hour feature is just like a 2X4 which is 1 5/8 X 3 5/8 inches, nominal measure. Many years ago when I was using a Hampden 105 to run freight trains it was wound once a day as close to the same time as possible and it never varied out of railroad specs. A 48 hour run with the same performance would have been a bonus, for sure.
Posts: 45 | Location: Maine in the USA | Registered: April 27, 2010
Picture of Michael P. McNamee
Hi Paul,
If you check out the IHC Illinois research forum,
https://ihc185.infopop.cc/eve/f...1029912/m/4231069691
you'll see that the 23j Sangamo Specials were produced with 60-hour mainsprings beginning in the mid 1920s. The earliest 60-hour movements, I believe, were not so marked on the movement, but the later ones were. Prior to that, they were standard 48-hour movements. For example, my ca. 1921 SS Model 10 that is pictured on my avatar came before the 60-hour movements were produced.
Posts: 1088 | Location: Minneapolis, Minnesota in the USA | Registered: October 15, 2013
IHC Member 1291
Great answer Michael !!
Thank you very much Mike for the clarification, I couldnt find that in my books, ...
Paul Davis
IHC Member 1911
You can always tell quickly if it is 60hr or not by the balance cock- Early 48 Hour ones have the border on the balance cock- later 60 hour ones do not have a border- easy way to tell at a glance.
Terry Jones
Posts: 84 | Location: Central Illinois in the USA | Registered: December 12, 2013
Administrative Assistant
Picture of Dr. Debbie Irvine
In the link that Mike referenced, Lindell posted the following information...
________Note: The 48-Hour Model 10 should stop by number 4167000_______
_____________________________________________________________
________Note: From this point Sangamo Special movements are 60-Hour_____
...and looking at the images he posted you will find "Sixty Hour" spelled out.
Posts: 5773 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
Thanks for the compliment, Buster. Coming from you that means an awful lot.
You're welcome, Paul. Illinois watches are one of my favorite to collect, and I've spent a ton of time researching them!
Dr. Debbie's terrific contributions need no further comment from me. Smile
