992 Case screws "Click" to Login or Register
IHC Member 1668
Picture of Donnie Tackett
Hi,
Do the case screws for the early model 1 992's have smaller diameter heads than the newer 992's have?
Thanks, Smile
Donnie T.
Posts: 84 | Location: West Virginia in the USA | Registered: January 30, 2012
IHC Vice President
Pitfalls Moderator
How about a picture? I'm not sure what you mean by "smaller."
Donnie,
Case screws were slightly smaller on the earlier Hamilton 16-size watches than those used later, but I agree with Ed that we could not guarantee authenticity of components without seeing the watch in question.
IHC Member 1668
Ed,
I bought this watch in a swing out case which had the flat head type screws seen in the picture below. I was going to put it in a different case and was going to use some case screws from another newer 992 but the screw heads will not go down into the recesses of the movement and will not allow the case screws to tighten down against the case, thus the movement is loose in the case.
Confused
It looks to me if the case screw heads were smaller they would go deeper into the movement, allowing the movement to tighten to the case.
Donnie T. Smile
IHC Member 1668
I suspected the earlier screws heads were a fraction smaller when the newer ones would no go all the way down.
Donnie
Yes Donnie, here is proof the case screws are ever so slightly smaller on the earlier Hamilton 16-size watches, see the example of a Grade 990 below this posting which is also in a Swing-Out Case. Observe carefully how the case screws fit very precisely, look closely, nothing like seeing the evidence clear and close-up! Lindell Wink
This early model number 374629 is entirely correct...
IHC Member 1668
Thanks Guys!!! Smile
Donnie
