May 11, 2013, 17:46
Donnie Tackett992 Case screws
Hi,
Do the case screws for the early model 1 992's have smaller diameter heads than the newer 992's have?
Donnie T.
May 11, 2013, 19:38
Edward L. Parsons, Jr.How about a picture? I'm not sure what you mean by "smaller."
May 11, 2013, 20:46
Donnie TackettEd,
I bought this watch in a swing out case which had the flat head type screws seen in the picture below. I was going to put it in a different case and was going to use some case screws from another newer 992 but the screw heads will not go down into the recesses of the movement and will not allow the case screws to tighten down against the case, thus the movement is loose in the case.
It looks to me if the case screw heads were smaller they would go deeper into the movement, allowing the movement to tighten to the case.
Donnie T.
May 11, 2013, 20:52
Donnie TackettI suspected the earlier screws heads were a fraction smaller when the newer ones would no go all the way down.
Donnie
