I just bought this Ansonia regulator that is weight driven and has a second hand. I need to know what size weight will I need to buy. Plus the name of the broken / missing part that goes on the top of the pendant stick.
Any other info would be helpful. Thank you ahead of time. And please correct me if I'm Calling some of the parts by there incorrect names.
I'm a watch guy that is starting to look at clocks.
Posts: 3329 | Location: Illinois in the USA | Registered: July 06, 2010
Thank you Dave. Yes I can make this part. I have some round brass stock and I believe I have a thin suspension spring. I might have to take the dial off my seth to see how the pendulum stick is attached to the thin spring.
The post with the slot. Is what I am going to need to make. Ok I took a piece of round brass and turned it down to fit the flat piece of brass that was still attached to the clock. Cut a slot. Then found some broken suspension springs and fab ed a new one. The pendulum rod is now hanging and swinging. Now I need to buy a cable and borrow the weight of the Seth #2 to see if it will run.
I used a 1" long by 1/2 wide brass brush to get down in the wood grain. In 10-15 areas I had to use my finger nail. Burlap is a better idea than steel wool. I'll try to remember that trick. Thanks
