  Welch calendar regulatorGo  ![]()  | New Topic  ![]()  | Find-Or-Search  ![]()  | Notify  ![]()  | Tools  ![]()  | Reply to Post  ![]()  |    |
 Just bought a Regulator with a calendar on the main dial this weekend and want to find out all I can about it.  It is time only, no strike.  Wood is oak with designs around the perimeter of the dial and the box at the bottom. The remnants of a label on the back has "...LCH" so I'm guessing its a Welch. Looks to be a good refinish, except the hinge is weak (the bezel/glass drops ~ an inch or so when you open it). The paper dial is a replacement that was not done very well. Got a new dial ordered from SLarose. There is no door and the back looks to be nailed shut... how do you get in this thing. The calendar is on the right day, but just in case, how do you set the calendar if it gets off. It is keeping time tick for tock with my grandfather, and the calendar hand has moved toward 13th in the last hour or so. It didn't seem to be moving earlier in the day. Lastly, the octagon surround looks to be nicely refinished, but it was put back on canted to the right. Is this screwed on from the back? Sorry for all the questions. New toy excitement. Thanks, Charlie HOLD IT ! HOLD IT ! The calendar hand just jump to the 13th ( about 6 mins early). ![]()  | |||
 Charlie, Calendar clocks are nice additions to a collection. Most simple calendars are set just by moving the hand with your finger. You will notice that it moves with a "click" for each day. If it does not readily move, then it is probably getting ready to change. The pin on the cam that moves the hand is engaged. It does this slowly. You just have to wait for the date change to move it further. The way into the clock is to remove the hands and dial. I will check the books I have to see if I can come up with a positive ID. Great looking clock!!! Tom Seymour NAWCC #41293 IHC #104 IHC Exec.V.P.  | ||||
 Charlie, It appears to be a Sessions. that pattern on the pendulum bob was typical of Sessions. Two models had that type of molding. One was 32.5 inches high (1908) and called the "Star Pointer." The other was 38.5 inches high and appears in Trans' book to be a light colored finish. It was made for the spanish market and called "Crescent No.8" (1915) Tom Seymour NAWCC #41293 IHC #104 IHC Exec.V.P.  | ||||
 One more day and the calendar seems to be working as you described.   Thanks for all the info Tom. This one is 32.5" Any guess as to the "INTE" or "INTB" at label top. Charlie [This message was edited by crsides on October 13, 2003 at 22:51.] ![]()  | ||||
 Pic of back ![]()  | ||||
 Obviously from the label I was wrong about it being a Sessions.  Although there is a sessions that is identical to it. This one is an E.N. Welch. The letters at the top of the dial are the ending of "STAR POINTER". I appears to be identical to the Sessions "Star Pointer" except for the pendulum. The pendulum bob is not like yours, but rather smooth. I will try to scan both and post them. Tom Seymour NAWCC #41293 IHC #104 IHC Exec.V.P.  | ||||
 Sessions Tom Seymour NAWCC #41293 IHC #104 IHC Exec.V.P. ![]()  | ||||
 Welch Tom Seymour NAWCC #41293 IHC #104 IHC Exec.V.P. ![]()  | ||||
 The "fish tail" or fan shaped end of the calendar  hand is not shown in the pictures, but is shown used by Welch as a calendar pointer on some double dial calendar clocks.  New Haven used the that style on some of their calendar clocks similar to yours.  Probably others did also. Tom Seymour NAWCC #41293 IHC #104 IHC Exec.V.P.  | ||||
 Obviously Welch had a big influence on the Sessions.  I would match it up as a Sessions also, except for the label.  Some kind of transition maybe? Definately a Star Pointer. A real sexy name for a clock, but why Star Pointer... I don't get it. Looking at the prices on the scans, I sense I overpaid. Thanks again for your help, Tom. Charlie  | ||||
 STAR  POINTER I think I figured out the connection. To navigate by the stars (which would have been popular in those days) you have to know the TIME and the DATE.  | ||||
 In 1903 the Sessions brothers who worked for the Welch Co. took over the defunct E.N. Welch business. They stopped production of the high end Welch clocks but continued to produce many of the lower priced ones.This clock had to be produced very near the transition date. Check the movement if it is signed by Welch then you probably have a Welch clock, if the movement is signed Sessions then you would have a early transition clock possibly using a left over case.   JACK  | ||||
 Jack, Welcome to the IHC #185 Chapter Site    Mike Nardick NAWCC # 144409 IHC Charter Member 26 Member Allegheny Chapter 37 mikena32@comcast.net  | ||||
