Seth Thomas Mini Beauty "Click" to Login or Register
Picture of Tom Seymour
This clock is part of the Will Roseman collection that is visiting my shop at the moment.
While this looks pretty much like an average clock at first glance, a closer look makes is a real treasure. The detail and quality is a cut above.
One of the real attractions of this clock is its size. From the first picture you can't relly tell, but here next to a Seth Thomas sonora you can see that its small size, only 9.5 inches, makes it quite attractive.
The dial is porcelain and the glass is convex and beveled.
It appears to be the Essex model from around 1913.
This picture is from Tran's Seth Thomas book.
The 48J movement was first shown in the 1917 catalogue.
If there is interest, I will take some pictures of the movement when I get it out of the case.
The movement is a nice compact little round time and strike movement. It appears at first that it has springs in barrels, but actually they are in round "boxes".
Hi Tom,
I just serviced a 48R movement from a ballon cased "Savoy" c1905. The pendulum had a cylindrical bob (brass) approx. 3/4" in diameter and 1 1/2" long. The overall length of the complete pendulum was approx. 6".
I would like to know your thoughts on the tension spring that rides on the center arbor.
Joe
Joe,
I don't have the movement out of the case yet. I have a couple of clocks to get to before this one. When I do get it out, I will take a look at what you are referring to. It has been too long since I have done one of these movements to remember exactly what you are asking about. As soon as I get it out I will take some pictures and we can discuss it from there.
This clock did not have the cylindrical bob, but rather the traditional disc. I will also include a picture of that when I get it on the bench.
Do you have any pictures of the 48R?
Picture of Grant Perry
Hi Tom:
Nice clock. Great dial. What $ does Tran put on these?
gp
Grant Perry
Posts: 334 | Location: Ottawa, Canada | Registered: January 28, 2003
Tran's book has it at $325.00
Tom,
I only took one picture of the 48R movement which was a picture of the tension spring I mentioned in the earlier post. Below is a picture of the clock along with the picture of the spring. Like your clock this "Savoy" has beveled, convex, lense.
Joe
That looks interesting. Offhand I can't think of what it might be for. I will let you know what the 48J has when I get it apart.
Hi Tom:
Great timing for this topic. Here is one I picked up today from a gent in our club. He tells me he thinks itis the Tudor?? Can you check in your book for me? Looks similar to yours, but notice the top is rounded and the case appears much more thin walled.
Best regards,
Grant
Grant Perry
c
case
Grant Perry
case
Grant, How tall is that one?
Hi Tom:
The case is 8.75 inches.
Best regards,
Grant
Grant Perry
Grant,
You do indeed have the "Tudor".
Here is the info from Tran's Seth Thomas book.
Picture of Greg Reeves
Joe, Is your photo of the inside of the back plate?
Yes Tom, the spring is inside and bears on the center arbor as shown. One of the guys on the Green board said it was to keep the slack under control so it will be as accurate the first 30 minutes of the hour as it is the last 30. Makes sense as there is almost 2 minutes slack in the one I worked on. The center arbor is not "in" the drive train it is along side of it. The only preassure it is subjected to is that required to drive the motion work.
Joe
Here is an update on this cute little clock.
It is perking away keeping great time.
back.
Strike train
both trains
Joe, this one does have the bar type spring riding on the center post. I would imagine it is, as ws mentioned, to keep any play out of the minute hand as it changes from before and after halfway points around the dial.
