January 06, 2010, 13:09
Ken KnightGut, Cable, Mono-Filament Line ???
A customer brought me a 1775 English bracket clock for repair. The works are fuzee driven and the previous "smith" used mono-filament fishing line between the barrel and fuzee. I decided to restore it to its previous state and use gut. Well, after a few months, the gut broke and the clock is back. Someone said use brass cable, rather than the gut. The mono-filament line works, but needless to say is a poor substitute.
What would you folks recommend? This clock is over 200 years old, and these things have worked with gut before. Perhaps there is something I can do with the gut to insure it holds up.
Thanks for your help.
January 21, 2010, 07:18
Robert V. ShansUse Steel cable. Why take a chance on it breaking and doing a lot of damage.
Bob
January 21, 2010, 09:23
Eddie G. HinesGREETINGS KEN, WHAT SIZE GUT DID YOU USE? YOU SHOULD TRY THE UK OR GERMANY FOR GOOD QUALITY GUT. TAKE CARE. EDDIE
January 21, 2010, 13:08
Clive DriscollAll
Bronze line should be fine, I've used it for years without trouble. Check that the holes are smooth, my guess is that there may be a sharp section which cut the line.
If you use bronze line you will have to anneal the ends so that you can tie a decent knot etc, just heat it to red heat over a torch and allow it to cool.
Cousins material supplies in the uk stock bronze line (they have a web site)
Hope this helps
Clive
