Gut, Cable, Mono-Filament Line ??? "Click" to Login or Register
Picture of Ken Knight
A customer brought me a 1775 English bracket clock for repair. The works are fuzee driven and the previous "smith" used mono-filament fishing line between the barrel and fuzee. I decided to restore it to its previous state and use gut. Well, after a few months, the gut broke and the clock is back. Someone said use brass cable, rather than the gut. The mono-filament line works, but needless to say is a poor substitute.
What would you folks recommend? This clock is over 200 years old, and these things have worked with gut before. Perhaps there is something I can do with the gut to insure it holds up.
Thanks for your help.
Posts: 285 | Location: Springfield, Ohio in the USA | Registered: June 06, 2008
Use Steel cable. Why take a chance on it breaking and doing a lot of damage.
Bob
Posts: 130 | Location: Fredericksburg, Texas U.S.A. | Registered: September 25, 2004
GREETINGS KEN, WHAT SIZE GUT DID YOU USE? YOU SHOULD TRY THE UK OR GERMANY FOR GOOD QUALITY GUT. TAKE CARE. EDDIE
Ken, Robert and Eddie,
A disaster caused by the sudden breaking of old-time "gut" stringing which led to the topic "Seth-Thomas Number 2 Case - Help!" caused me to do some reworking of the case and change over to bronze or brass cable. Since it is available in a wide variety of guages to fit practically any application and is even available with a nylon cord core essentially the way modern-day tires are made I feel a whole lot more comfortable.
I do not go with mono-filament because for me the bronze or brass is easier to work with, operates more smoothly and has a somewhat more attractive "original" look particularly on the later Seth-Thomas Number 2 applications where the cable will be partially in view most of the time.
All
Bronze line should be fine, I've used it for years without trouble. Check that the holes are smooth, my guess is that there may be a sharp section which cut the line.
If you use bronze line you will have to anneal the ends so that you can tie a decent knot etc, just heat it to red heat over a torch and allow it to cool.
Cousins material supplies in the uk stock bronze line (they have a web site)
Hope this helps
Clive
Posts: 264 | Location: Westbrook, United Kingdom | Registered: June 15, 2007
