Hall Clock IdentificationGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Hello, I am new to your group. I have been a watch and clock repairman in the Prescott, AZ. area for 30 years. I have been semi retired for the last several years, but a friend needed some help, so I am back at it. Anyhow, I acquired this huge German floor clock and would like to get some more history on it and a idea of value. The case is 7'6" tall and 43" wide at the top, movement is a Kienzle 3 weight Westminster chime.It is dark oak with some nice carvings. Any help would be appreciated. Thanks, Mike Nelson Mike N. ![]() | |||
Here are a few more photos. Thanks, Mike Nelson ![]() | ||||
One more photo... ![]() | ||||
4 Mike N. ![]() | ||||
5 Mike N. ![]() | ||||
| IHC Life Member Moderator |
Mike, Welcome Aboard! That is a beautiful clock, it will be interesting to watch it come together. Don | |||
| Administrative Assistant |
Mike, Welcome to IHC185. You have a very interesting clock with beautiful workmanship. Thanks for sharing it with us. Debbie | |||
Mr. Mike: Does that movement have a set of crossed arrows on the other side? If it does is is likely a Junghans -made in Germany. The front side reminds me of one I just repaired. The way the levers are mad and arranged makes it look similar. The case is just beautiful. | |||
Hello Moses, Thanks for the reply. The movement is marked Kienzle on the front plate and the # 115 on the rear along with a 30741 serial number. I don't know if the 2 companies did any movements that were similiar. Mike Mike N. | ||||
Hi Mike, WOW, whatever the value is, it's got to be huge! At least to me. I think is fantastic, so I would hang in there until you find the complete answer to this one. I'm a pocket watch person, so I can't really help you with this one, but I know a gorgeous case when I see one, and this one is one of them. I have seen clocks like this, with this type of case, go for many thousands of dollars, however I have no idea what kind of movement they had in them, and as I'm sure you know, it does make a big difference. Good luck, Sheila | ||||
| IHC President Life Member |
Did you get the SIZE of that clock? Mike said 43" wide at the top, seven and a half feet tall, that would command nearly any room! Really interesting clock, like Don said it will be fun to watch it progress. Lindell | |||
