Hall Clock Identification "Click" to Login or Register
Hello, I am new to your group. I have been a watch and clock repairman in the Prescott, AZ. area for 30 years. I have been semi retired for the last several years, but a friend needed some help, so I am back at it. Anyhow, I acquired this huge German floor clock and would like to get some more history on it and a idea of value. The case is 7'6" tall and 43" wide at the top, movement is a Kienzle 3 weight Westminster chime.It is dark oak with some nice carvings. Any help would be appreciated. Thanks, Mike Nelson
Mike N.
Posts: 10 | Location: Dewey, in Prescott Valley Arizona | Registered: April 13, 2008
Here are a few more photos. Thanks, Mike Nelson
One more photo...
4
Mike N.
5
Mike N.
Moderator
Picture of Donald Trumble
Mike,
Welcome Aboard!
That is a beautiful clock, it will be interesting to watch it come together.
Don
Posts: 504 | Location: Pennsylvania in the USA | Registered: April 02, 2005
Administrative Assistant
Picture of Dr. Debbie Irvine
Mike,
Welcome to IHC185.
You have a very interesting clock with beautiful workmanship.
Thanks for sharing it with us.
Debbie
Smile
Posts: 5877 | Location: Northern Ohio in the U.S.A. | Registered: December 04, 2002
Moderator
Picture of Moses Gingerich
Mr. Mike:
Does that movement have a set of crossed arrows on the other side? If it does is is likely a Junghans -made in Germany. The front side reminds me of one I just repaired. The way the levers are mad and arranged makes it look similar.
The case is just beautiful.
Posts: 143 | Location: Sarasota, Florida in the USA | Registered: March 31, 2005
Hello Moses, Thanks for the reply. The movement is marked Kienzle on the front plate and the # 115 on the rear along with a 30741 serial number. I don't know if the 2 companies did any movements that were similiar. Mike
Mike N.
Picture of Sheila Gilbert
Hi Mike,
WOW, whatever the value is, it's got to be huge!
At least to me. I think is fantastic, so I would hang in there until you find the complete answer to this one.
I'm a pocket watch person, so I can't really help you with this one, but I know a gorgeous case when I see one, and this one is one of them.
I have seen clocks like this, with this type of case, go for many thousands of dollars, however I have no idea what kind of movement they had in them, and as I'm sure you know, it does make a big difference.
Good luck,
Sheila
Did you get the SIZE of that clock?
Mike said 43" wide at the top, seven and a half feet tall, that would command nearly any room! Really interesting clock, like Don said it will be fun to watch it progress.
