Jumpy Second Hand "Click" to Login or Register
Picture of Francesco Marco Maraschin
posted November 20, 2013 05:57
Hi all
Ive got a Longines watch that has a very jumpy second hand, the jumping is also very irregular, would there anything to worry about or is there just a lot of play in the gears?
The watch keeps great time and i think it is only the play in the gears but i thought i would ask just to get your guys opinion.
Thanks All
Francesco.
Posts: 226 | Location: Johannesburg, South Africa | Registered: November 19, 2012
posted November 20, 2013 05:59
Said watch. Sorry for bad photos
posted November 20, 2013 06:05
2
Picture of Dan Carter
posted December 01, 2013 10:38
Could it be a problem with the seconds gears? Check for debris near the shafts or on the gears them selves. If the other hands are doing fine then I would focus on the seconds gears. Also, how does the second hand look? Make sure it is not slipping. Not sure if it helps, just ideas.
IHC Member 1856
posted December 01, 2013 15:37
During that time I think Longines produced movements with indirect drive second hands. The fourth wheel was connected to the second hand via a very delicate pinion. In normal operation the second hand would appear to hang up for a second and then jump forward abruptly. If you can find a video of a Chopard LUC 2000 movement, it is an example of a modern indirect drive second hand. It doesn't affect the accuracy of the watch, it just looks a little sloppy if you see it happen.g
Posts: 31 | Location: Anniston, Alabama in the USA | Registered: May 27, 2013
posted December 02, 2013 06:30
I agree with Geary, the indirect method of drive from the fourth wheel can sometimes affect the running of the seconds hand. I have two watches that do this, a Bulova type All navigators watch, and a 1940's Oris.
It does not affect the timekeeping, just looks strange. It does not do it when the watches are "flat", on a table or other surface either.
Posts: 77 | Location: Ilkeston in England | Registered: March 22, 2013
