As we move on we must learn to service the watchmaker who is trying to get Aunt Millie's watch to work with a quartz movement because she can no longer wind it, as well an the collector trying to restore the most precious thing thing he owns-his Dad's WW2 wrist watch. Sorry Mark.
Rob
Understood, and appreciated, Rob. In my case, all I wanted was the dial brought back to what it was when originally received.
Warmest regards! Mark
Posts: 3840 | Location: Estill Springs, Tennessee, USA | Registered: December 02, 2002
Thanks for that Rob. I avoid getting pearled dials refinished unless absolutely necessary, and I can usually spot one immediately from the out-of-line dots.
Another problem relates to re-luming hands to match the dial figures color - the stuff used seems to very easily crack away from the hand and fall out. I am often having to coat the back of re-done hands with epoxy to stop this.
Dan
Posts: 423 | Location: West Walton, United Kingdom | Registered: November 16, 2005
Rob, I sent you folks a very rough, painted Illinois dial and I thought you did a very nice job. It was pointed out here, however, that the fonts of the numbers and lettering were a bit different.
I didn't mind and thought I got more than my money's worth.
Since then, however, I have been told (unsubstantiated) that you have original dies for Hamilton, Elgin and Waltham but not for Illinois. Thus, I've heard, you can match fonts and styles much closer for those brands.
Any truth to all that? Can you elaborate a bit?
Posts: 986 | Location: Flagstaff, Arizona USA | Registered: June 19, 2005
Dan-- thats the first i've heard about the luminous material falling out. Any others out there with that problem?? We mix our compound ourselves as the stuff available just isn't any good (for our purposees)
Peter-- I'l answer your question on the Pocket watch discusion board later today. Your is the situation that finally promted me to start this whole thing
Posts: 8 | Location: Southwestern Ohio in the USA | Registered: May 02, 2007
Bits falling out is very rare - probably the stresses associated with fitting the hands have much to do with it. On watches with a sub-seconds hand the hour and minute hands often have to be bent slightly up after fitting, to get the correct clearances.
Hey Samie, Hot! You bet and DRY too! Trying to stay cool... in the pool..., but got to keep addin' water to it every other day! Oh Yeah! Not sure but think we have some cactus pokin' up in the front yard... I think we're the new Arizona!!
Joe
Posts: 150 | Location: Milan, Tennessee USA | Registered: December 20, 2005
yes that,s what i did ,i have in the past used the black enemal from casker,s and heat to set it works good but a little tricky to do...I plan on listing this one on ebay later today frist one i have had without nay brass showing...
Bryan gave me this tip on how to fill-in the enamel a while back, and it works well. You just brush-on black enamel paint (Testers model enamel or similar works fine), wait a few minutes (not too long!), and wipe off the enamel with a papertowel or piece of thin fabric. Be careful not to wipe the enamel out of the engraved areas. I have also done this after intentionally thinning the paint a little with thinner, and this seems to reduce the risk of waiting too long and having the paint dried on the raised portion you are trying to wipe off.
I presume you are doing something similar?
Rick
Posts: 141 | Location: Michigan in the USA | Registered: October 13, 2005
@Rick Vess - Right after I got out of college, I worked for a year or so at an auto restoration shop called Hemphill's Healey Haven, where we specialized in restoring Austin Healey sports cars. We used to do the dashboard control knobs and switches the same way, but with white paint, because the knobs were black.
This was in the late 1970's, so replacement luminous dial faces for gauges were still available from Smiths Gauge Company in England.
Posts: 213 | Location: Westminster, Maryland in the USA | Registered: March 02, 2015
