IHC Life Member Certified Watchmaker ![]() |
Busy today working on a old, Heuer Cal 12, need a lot of work apart from basic service & crystal. autoweight axle broken no more of those part to be found so had to be made. Also found the tiny pivots on a click had broken and that also had to be replaced. | ||
You can see the tiny shaft in the green and the new one fitted side on (those are MM on rule) ![]() | |||
Of course nothing is easy and the part had to be hand made 0.85mm long 0.38mm diameter & pivots 0.10mm I did have a part that was close to start with so just a matter of turning it all down to size | |||
Those Autavia are classic watches and worth to be repair no matter the cost. Thanks for showing to us . | |||
