Case size questionGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Pic. shows a case for a negative set small pocket watch movement. The question is -- what size ? The internal diameter of the back varies a few tenths of a mm below 29 mm, depending on where it is measured. It could be size 0, 2, or perhaps even 3 ? Dan. ![]() | ||
Hi Dan, A 2/0 movement at 28.78mm looks to be a good fit. Joe | ||||
I think it is for an 0 size movement.The outside rim of the movement is larger than the main body of the movement.The case it fits in will be smaller than the rim. J Smith | ||||
Dan, If it's the same as this one... which has the same markings and measurements as yours, then it's for an 0 size. Mine holds an Elgin 0 size with it's dust ring intact very snugly. Regards, Cary | ||||
Thanks for the notes. Now I need a Hamilton 0-size movement and dial and hands ! dan | |||
