My old clock? "Click" to Login or Register
posted February 02, 2003 20:35
Hey clock guys, What do I need to identify my Seth Thomas cabnet clock? I do not see a serial mumber anywhere easily viewable. Thanks, I am basicly looking for an age and a qrade/quality.
Aaron Bereiter
NAWCC# 156432
Very Proud IHC Charter #55
You will never prosper if you live your life in fear.
Picture of Tom Seymour
posted February 02, 2003 21:34
Aaron, How about starting with a picture? I would be happy to help identify the clock. Without a picture, a more detailed description of the case and movement would help.
NAWCC #41293
Internet Horology Chapter #104
IHC Exec.V.P.
posted February 06, 2003 08:59
Tom, I'm working on getting a picture right now. I gotta chace down my lazy brother first. Wink
Dont forget about me brother, I'm still here.
Aaron Bereiter
NAWCC# 156432
We rise highest when we stoop to help others.
posted February 06, 2003 10:56
Aaron,
I'll be looking for the pic when you get it. I know you are there, I've been reading your other posts. Good luck at the Ch.69 meeting.
NAWCC #41293
IHC Exec.V.P.
posted February 11, 2003 19:17
A couple of fotos.
Aaron Bereiter
NAWCC# 156432
Seth Thomas clock
posted February 11, 2003 19:18
And another.
Aaron Bereiter
NAWCC# 156432
Inside
posted February 16, 2003 00:10
Hi Aaron, I just got back in town. There are a ton of emails to go through, but I had to take a look here first. Just a quick response, then, when I get a chance I will seeif I can dig up more.
Clocks don't have serial numbers or grades. The label on this one indicates that it was 1865 at the earliest. The town of "Plymouth" was changed to "Thomaston" in 1865.
If you still have the camera and could get a shot of the movement without the dial, that would be good. When I am more awake tomorrow I will try to track down the movement dates. It is one of the earlier ones (raised rings around the wheels).
More later!
NAWCC #41293
IHC Exec.V.P.
posted March 02, 2003 14:04
Hey guys, How hard would it be for me to tear this thing down, clean it and oil it? I can do my pocket watches so how about this old clock. It is weight driven so there there is no mainspring to deal with. What would I oil it with? I have some Moebius 8200 would this be sufficent for the pivots?
How about cleaners and a rinse? Would my watch solutions work?
Just a little advice needed.
Aaron Bereiter
NAWCC# 156432
Chapter 185 Charter #55
Chapter 185 Finance VP
posted March 02, 2003 16:24
Aaron, Piece of cake!!
Have fun. If you run into any problems....just ask! I'll bet you won't have any problems with this if you have done watches. The new territory is the strike train. Look carefully at how things line up before you dissassemble. The locking pins and lifts for the hammer have to be at the proper spot for the strike train to work properly. Move it manually to the locked position, if it not already there, and note the relative orientation of each of the strike train wheels. Take a couple of pictures!
Have fun!
Tom Seymour
NAWCC #41293
IHC #104
IHC Exec.V.P.
posted March 09, 2003 10:24
Tom,
Thanks for the advice. What should I oil this thing with? I have some Moebius 8200 would this work? What do I oil? Just all the pivots? Anything on the escapement? Just a few basic questions. Thanks,
Aaron Bereiter
NAWCC# 156432
Chapter 69 So Cal.
posted March 10, 2003 20:32
Aaron,
I generally use LaPerle, Clock oil. Havev used it for many years and it has done well. I also tried a synthetic clock oil called "Etsyntha Chemie - clock 859". The label also states "Dr. Tillwich GMBH-7240 HORB-AHLDORF. I have not had any trouble with this product either, although I have not used it as much as the LaPearle. Both are available from LaRose.
I put a very light coat of PML, Stem Grease on the pallet surface. I learned that from the clockmaker I learned from and have done that for 20+ years without a problem.
Tom Seymour
NAWCC #41293
IHC #104
IHC Exec.V.P.
<Tom Chaudoir>
posted March 22, 2003 01:27
Hi Aaron,
Before you tear into it, set it up on a fixture and live with it for a while. Watch it run, and keep coming back until you understand how it works. See how the levers interact? When the count wheel lever comes down in a slot, the warning wheel has to be in just the right place, as far as the orienation of the pin. Note where that is. Once you understand the strike sequence, you are the boss.
As for lubrication, try this.
P.S. I just looked and have the brother of your clock out in the shop. Not as nice as yours. The original dial is gone. Someone painted a board to replace it. As long as the paint brush was loaded, they covered the ugly old maker's label on the inside back. Oh well. They sent it all the way to the 21'st century to someone who will care for it. I guess that's something.
Best,
[This message was edited by Tom Chaudoir on March 22, 2003 at 1:46.]
