Clock Repair Questions and Answers
Gilbert Crystal Regulator issuesGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Gilbert Crystal Regulator issues I purchased the above crystal regulator about 5 years ago. It worked for a few days and then the time spring broke. I took it into the clock repairman I used to use and he fixed the spring (actually, he just cut the spring down and punched the end) I get about two to three days out of a full wind. I have been looking for the correct mainspring which is a 3/4 x.15 x 96" hole end. The problem is, I can seem to find any with a .15 thickness. There are a ton of .18 thickness springs out there. My question is can I use the thicker spring or am I stuck looking for a very rare spring. Bruce Bruce Byrd | |||
Have you tired Timesavers? link to timesavers mainsprings | |||
Hi Roger, I looked at timesavers and the closest I found was (3/4" X .0165" X 96" Loop End 8-Day Mainspring). Do you think the extra .0015 is going to matter? Bruce Byrd | ||||
Bruce, I would probably go with this one: link I don't think .003 is going to make all that much difference, but here is another option: link that should work fine too. Both of these are hole end springs which I think is what you said you need. If you are concerned about overpowering the train, go with the thinner spring. There are a couple of others there to consider. Look thru the hole end mainspring selection. Roger | |||
Thanks for the info Roger. I am gonna buy the springs and have someone install them. the thought of taking that three plate movement apart has me terrified. Two plates I am ok with.. Three.... not so much Thanks again for the info bruce Bruce Byrd | ||||
You're welcome Bruce. Clock mainsprings are nothing to mess with if you don't have a good winder and know how to use it. Mine cost a few hundred bucks, but I like to keep all my fingers and other body parts. | |||
