October 11, 2013, 12:30
Bruce ByrdGilbert Crystal Regulator issues
I purchased the above crystal regulator about 5 years ago. It worked for a few days and then the time spring broke. I took it into the clock repairman I used to use and he fixed the spring (actually, he just cut the spring down and punched the end) I get about two to three days out of a full wind.
I have been looking for the correct mainspring which is a 3/4 x.15 x 96" hole end. The problem is, I can seem to find any with a .15 thickness. There are a ton of .18 thickness springs out there.
My question is can I use the thicker spring or am I stuck looking for a very rare spring.
Bruce
October 11, 2013, 17:04
Roger J. NolfeHave you tired Timesavers?
link to timesavers mainspringsOctober 16, 2013, 20:10
Bruce ByrdHi Roger,
I looked at timesavers and the closest I found was (3/4" X .0165" X 96" Loop End 8-Day Mainspring). Do you think the extra .0015 is going to matter?
October 17, 2013, 09:03
Roger J. NolfeBruce,
I would probably go with this one:
linkI don't think .003 is going to make all that much difference, but here is another option:
link that should work fine too.
Both of these are hole end springs which I think is what you said you need.
If you are concerned about overpowering the train, go with the thinner spring.
There are a couple of others there to consider. Look thru the hole end mainspring selection.
Roger
October 21, 2013, 14:38
Bruce ByrdThanks for the info Roger. I am gonna buy the springs and have someone install them. the thought of taking that three plate movement apart has me terrified. Two plates I am ok with.. Three.... not so much
Thanks again for the info
bruce
October 21, 2013, 15:48
Roger J. NolfeYou're welcome Bruce. Clock mainsprings are nothing to mess with if you don't have a good winder and know how to use it. Mine cost a few hundred bucks, but I like to keep all my fingers and other body parts.
