It won't wind up! "Click" to Login or Register
Picture of Tom Seymour
posted January 21, 2005 23:46
I got an interesting email from an NAWCC member posing an interesting problem.
The problem was, after this person replaced a cable on a Sligh grandfather clock, he could only wind the clock 6" from the bottom of the case.
(We have solved the problem.)
The cable was installed correctly on the drum. The cable was the right length.
Would anyone care to guess how this situation could exist?
Picture of Andy Krietzer
posted January 22, 2005 13:47
Was something put on backwards? Like when I reassembled my Seth Thomas Adamantine movement, it struck the wrong time, 12 at 1:00, 11 at 2:00, 10 at 3:00, etc. I had put the count wheel in backwards.
Andy Big Grin
posted January 22, 2005 15:40
Andy,
Yes! Those nasty countwheels. I've been there.
No! Not the solution this time. He could successfully wind the weight from the bottom of the case to about 6" above the bottom.
posted January 22, 2005 18:55
Tom,
Your friend had the stop works out of phase with the cable. Some times, when the stop works is installed improperly, the clock will only allow 6-8 iches of the cable to play out after being wound.
I have had clocks brought to me with this problem fresh from another repair place.
Dick Feldman
posted January 22, 2005 20:31
Dick is absolutely right.
Geneva stops, used on a few of the older models of American shelf and hanging clocks, was brought back for the newer grandfathers.
This one stumped me for a while. Back when I did a lot of work on grandfathers, they weren't using the geneva stops. When the cable was installed, the position of the stops was not taken into consideration.
I "solved" the problem (knowing where to get an answer is a major problem solving strategy) by asking my friend Norm (clock shop owner). It took him all of a half second to tell me what the problem was.
Picture of Grant Perry
posted January 24, 2005 20:53
Good evening:
Good evening:
I ran into a similar problem with my 15 day ST World. I knew the stop works needed to be set properly; however due to the fact that I didn't really study them on disassembly; it took a few tries to get them set correctly. The stop works are a great idea!
gp
Grant Perry
Posts: 334 | Location: Ottawa, Canada | Registered: January 28, 2003
posted January 25, 2005 22:14
Grant,
Seth Thomas used geneva stops more than others. What is common, is to find that a "repairman" of the past has disabled or discarded the geneva stops. Very common to not see them on a movement that should have them.
posted January 28, 2005 21:44
Maybe they were discarded by someone who could not figure out how to reset them on reassembly?
I guess you could also get more power from the springs with the stops off or disabled...
Grant Perry
posted January 28, 2005 22:04
Grant,
I believe your first coment is correct. They just didn't know how to set them, and unlike you, did not take the time to figure it out.
The "more power" theory sounds good, but the stops were designed to keep the timekeeping in the ideal range of the spring for most accurate timekeeping.
It is interesting to see them brought back for the newer models.
The Seth Thomas clock in the For Sale section has a good picture of geneva stops.
posted January 29, 2005 03:02
Although Geneva stops and Stop works function the same, the purpose is not. Stop works on a cable driven clock is designed to prevent two conditions. One purpose is to prevent the cable from unhooking from the cable drum on the low end. Hopefully the travel of the weights is limited by the floor of the clock case. I have, however, seen cable driven movements used in Gallery clocks, which have no floor. The other function is to prevent the drum from accepting any cable when full. If cable is allowed to double up on the drum, there is a good chance it will foul and tangle.
Since cable driven clocks have almost even power supplied throughout the run cycle, there is no advantage to eliminate the first and last part of the cycle. With spring driven clocks having Geneva stops, the idea was to “stop out” periods with higher and lower power, hoping to get a more consistent power supply to the movement.
posted January 29, 2005 10:02
Dick,
ABSOLUTELY RIGHT!! Well said, I was using the geneva stops and stopworks interchangeably and that is not accurate. You explained them very well. Thanks!
posted January 29, 2005 10:27
Thank you for the additional info Dick. That is what I LOVE about this hobby. I can learn new things every day. Thanks to you and Tom for the lesson!
gp
Grant Perry
posted January 29, 2005 14:48
Tom could you point out the Geneva stops on the spring driven Seth, that you have up for sale.I am not sure where to look for them, besides in the mainspring area.
Thanks Tom, interseting thread and thanks also to Dick.
posted January 29, 2005 15:02
Dick,
Does Herschede use the stop works on their cable drive movements? I noticed a shorter model in a funeral home, and I believe the weights will go all the way to the bottom of the case. A Christopher Columbus model is nearly a foot taller, which I thought meant it would run longer than the shorter clock. The weights will stop about a foot before hitting the bottom. Apparently the movement is set up identical no matter how tall the case is, it still runs the same length of time.
Andy
So many clocks, so little time.
posted January 29, 2005 15:52
AS requested,
here is a close up of the Geneva Stops on a Seth Thomas clock. There are variations of this design.
posted January 29, 2005 22:03
Andy,
I think all of the modern cable clocks have stop works. I have noticed that the top and bottom settings on them are pretty much the same, regardless of the case length. Consequently, even in a tall case, the weights can rest on the case floor without the stops being set. I have never worked on a Herschede, so I cannot say on that.
Stop works can be a real pain as the indexing marks on the gears usually are supposed to be aligned with the cable played out. Making the three weights stop at the same position when the clock is fully wound can be a real challenge as one tooth difference is noticeable. The gear that fits on the winding arbor has a choice of four positions because it has a square hole. The other gear free wheels on a post. The two will not normally mesh in the “locked” position but have to be lead into that position a couple of teeth ahead of lock. I usually set the stop with one loop of cable on the drum when locked on the bottom end. While this coordination is all going on, the loose ends of the cable are usually catching on one’s shoes or tangling around some tools or something. In my book, they could have done a better job with design. I suppose if a guy sat in a factory all day and set the stops on clocks, it would be “duck soup,” but it seems the length of time between me setting stops is just enough to forget the finer points. Evidently I am not the only one to be frustrated by stop works as I have seen a few clocks come in with the gears missing.
It gets to be kind of the question about where does the rubber from tires go when they wear. Somewhere there must be a coffee can full of stop works gears.
I don't have one in my shop now or I would send a picture of the mechanism. Till then I hope you enjoy the picture of Lake City Colorado
Dick Feldman
posted January 30, 2005 08:10
Thanks Tom for the explanation and picture, it makes sense since i can see it.Good idea also to have these on clocks.
Dick that is a nice picture, when did you take it? The mountains are beautiful and the trees. Smile
posted February 11, 2005 18:00
Here are a couple of pictures of the stops in a Sligh cable wind grandfather clock.
The arbor is wound clockwise and has stopped and dropped back a bit to the closest click position.
posted February 11, 2005 18:04
This shows the three winding arbors and their stops.
