Clock Repair Questions and Answers
Making a constant profile cutting millGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Hi there, I am a regular guest of yr Ch185 Military Watch Forum and also Administrator of the German Military Watch Forum elsewhere and I thought it would be good to post the flwg for yr perousal tnks rgds Enzo http://germanwatch.proboards43.com/index.cgi?board=gene...ay&thread=1196523072 | |||
Very interesting. 4cm is about 1.5 inches. That seems like a big diameter for a spring metal. I am probably misunderstanding, can you be more specific on the material you used? Thanks Rick | ||||
Hallo Rick, tnks and yes, dia is 1.5 inches. I use salvaged coil springs that you can find in sliding doors actuating system (which are 2 inch wide and 3/32'' thick) or similar assy's, I do not know if in US they have same components just like over here. Just to give you an idea the foil leaf of the car rear suspensions would be good as well but they are too thick.... Basically any steel that has an high tenor of Carbon (.50 .60) would be good enough. Pls ask if I was not clear enough. tnks rgds Enzo | ||||
Thanks Enzo, I was picturing a spiral spring but it sounds like you are describing a leaf spring which makes total sense. Thanks for the clarification. Rick | ||||
