Making a constant profile cutting mill "Click" to Login or Register
posted December 02, 2007 05:50
Hi there,
I am a regular guest of yr Ch185 Military Watch Forum and also Administrator of the German Military Watch Forum elsewhere and I thought it would be good to post the flwg for yr perousal
tnks rgds
Enzo
http://germanwatch.proboards43.com/index.cgi?board=gene...ay&thread=1196523072
posted December 02, 2007 11:46
Very interesting. 4cm is about 1.5 inches. That seems like a big diameter for a spring metal. I am probably misunderstanding, can you be more specific on the material you used?
Thanks
Rick
Posts: 93 | Location: Frisco, Texas in the USA | Registered: August 29, 2006
posted December 02, 2007 12:33
Hallo Rick,
tnks and yes, dia is 1.5 inches.
I use salvaged coil springs that you can find in sliding doors actuating system (which are 2 inch wide and 3/32'' thick) or similar assy's, I do not know if in US they have same components just like over here. Just to give you an idea the foil leaf of the car rear suspensions would be good as well but they are too thick....
Basically any steel that has an high tenor of Carbon (.50 .60) would be good enough.
Pls ask if I was not clear enough.
tnks rgds
Enzo
posted December 02, 2007 16:28
Thanks Enzo, I was picturing a spiral spring but it sounds like you are describing a leaf spring which makes total sense.
Thanks for the clarification.
Rick
