If you are looking for the exact shape click spring Larry, you just about can forget about finding it unless you find a parts movement with one on.
Most times you either buy one that will do the job that looks slightly different and might need modifying a touch or you make one from scratch like a lot of repairer's do.
Posts: 2260 | Location: Gladstone in Australia | Registered: January 14, 2011
Bila, Pretty much what I was thinking. If it was mine, I'd just buy the closest one I could find to what I need. You could then file a notch in it to lock into the plate or whatever it takes to make it work.
Dave Turner
Posts: 1979 | Location: Wilson, North Carolina in the USA | Registered: November 15, 2011
YOU CAN PURCHASE THE CORRECT SPRING FROM TIME SAVERS IN ARIZONA THEY HAVE A LARGE SELECTION OF CLICK SPRINGS JUST BE SURE THAT IT IS THE CORRECT SPRING BECAUSE THERE ARE LEFTS AND RIGHTS IN THE SELECTION. EDDIE HINES
Posts: 140 | Location: St. Paul, Minnesota in the USA | Registered: June 11, 2008
