Page 1 2 3
Waltham's Riverside Grade "Click" to Login or Register
Picture of Jerry Treiman
posted June 02, 2005 00:24
18s 1892 model is not in a case.
1888 model (16s) is in a silver case (AWWCo).
14s Colonial A is white gold (14K Wadsworth)
12s 3/4-plate in silver/niello case (Keystone - see other thread)
12s semi-bridge style - you are seeing the nickel swing ring from a Waltham sterling case.
10s Colonial B is in white gold (14K Keystone)
1s is in a silver case (AWWCo).
posted June 06, 2005 14:56
Jerry;
Thanks. Niello, huh? I sure know how to pick them!
- Mark Lee
posted June 06, 2005 16:23
I see that I missed your question about the 6/0 in the cushion case. I have always believed it to be original, but have no proof. I will post more details in the wristwatch forum where we can discuss the issue further.
South-Bend
Picture of Frank Kusumoto
posted June 09, 2005 19:41
Is this thread dead yet? Smile
An ad from the National Geographic, dated Nov 1915.
posted June 10, 2005 15:02
Frank;
Moribund, maybe, but never fully dead. That ad is very interesting. Do you have a date associated with it? I ask because it appears as though wristwatch production for men had not yet started. How accurate that presumption is, I do not know. The ad's date maybe an indication that Riverside movements made earlier than the ad and are in wrist cases for men are recased movements. Again, a brain tickler.
- Mark Lee
Picture of David Johnson
posted July 08, 2005 23:57
Jerry,
This one just arrived. Thought I would add it to the mix.
posted July 09, 2005 00:00
Here is the dial. I am not that familiar with the Maximus but it seems like I remember reading or hearing that some of the dials where marked "Waltham Maximus". Would the dial shown be correct for this movement?
RR Watch Expert
Picture of Ed Ueberall
posted July 09, 2005 11:15
The dials that I have seen that are marked "Waltham Maximus" were made for the Premier Maximus, in both porcelain and silver versions. The Riverside Maximus, at least in 16 size, seem to have used "Waltham" in flowing script as the original dial.
Of course, there may be exceptions, as Waltham, like most other watch manufacturers, wasn't very consistant. They would do whatever the customer wanted in order to sell watches.
Ed Ueberall
IHC Member 34
The Escapement
posted July 10, 2005 18:02
David, your dial is definitely an appropriate Riverside Maximus dial. The Waltham name is in the distinctive style used only on this grade. The only addition I have seen on some dials is "AWWCo." in script above the seconds bit (but this seems to appear on earlier examples than yours, such as some 12-size and the '88 model). Waltham made an effort around 1903 to switch to using single-sunk Maximus dials as opposed to double sunk because they were less susceptible to breakage.
posted July 10, 2005 18:31
Jerry -
Have you ever seen a Riverside Maximus wind-indicator with a dial carrying the distinctive script Waltham signature?
I've talked to an individual who believes he has seen such a dial, but every Riverside Maximus wind-indicator I have seen has had a plain block numeral "Waltham" signature.
Fred
posted July 11, 2005 03:22
No, I have not. (But I have only seen a few with wind indicator). I will contact a Maximus collector that I know and see if he has anything to add.
posted July 14, 2005 02:43
My Maximus source says that he, too, had heard of a wind indicator with a Maximus dial, but it turned out to have an italic script "Waltham" such as seen on some export watches (attached image, lower name), not the distinctive upright script normally used on the Riverside Maximus (upper name). Many people hear that the Maximus dial has the name in script and do not realize that there is a difference between the two.
posted July 14, 2005 10:25
Thanks for checking Jerry ... and now I definitely wonder if that wasn't what my friend perhaps saw also.
Would be very interesting if there was such a dial with the distinctive upright script, but until I more convincingly see or hear of one I think I will have to doubt its existence.
Fred
posted August 11, 2005 18:12
In the matter of type-faces, I would like to offer this one:
First, I should say that this is NOT from a Riverside dial, but from a Seaside 0s dial. The odd thing is that both a small-cap block lettering is used for the word "American" while a rather flourished script in used for "Waltham". The block lettering of "Waltham" has appeared on the non-Riverside grade watches that I have seen, but I have not seen both type-faces used together. My thought is that perhaps this watch, having been made in 1894, pre-dates any attempted standard practice that Waltham might have utilized.
P.S. The clumsy graphic clean-up is mine and the black strip down the middle is the minute hand of the watch.
- Mark Lee
South-Bend
posted September 12, 2005 10:54
One that I found in the junk pile. And it runs!
Picture of Fred R. Hougham
posted September 13, 2005 21:41
Jerry,
Was reading thru your excellent post on Waltham Riverside's and I just received this 1908 model Maximus Winding Indicator. Dial & movement pics enclosed.
Fred
posted September 13, 2005 21:42
movement
posted September 14, 2005 03:05
Frank - thanks for sharing the picture of your '84 model. The damasceening on these nickel movements is always fun.
Fred - thank you for sharing one of the TOP Riversides !! I imagine that the damasceening on yours is not shown off to its best advantage.
posted October 17, 2005 00:20
Finally had a chance to add the 3/0 Riverside to the gallery. This 21j movement (ca.1930) is based on the 0-size 1907 model.
  Powered by Social Strata Page 1 2 3
