IHC Life Member |
dis2 IHC Member 25 IHC Life Member (L6) ![]() | |||
IHC Life Member |
This example is made for an 18s Hampden. No bow, and hinged back and bezel. Not as common as other display cases. IHC Member 25 IHC Life Member (L6) ![]() | |||
IHC Life Member |
dis4 IHC Member 25 IHC Life Member (L6) ![]() | |||
Larry, Terrific pictures as usual!! I really like the display case with the hinged bezel. The only display cases that I have are the snap-on/off bezel type, and I guess this is ok if you have a pendant set movement , but are a pain in the neck when it comes to setting the time if there is a lever set movement involved. ![]() Phil Dellinger NAWCC# 157070 IHC Life Member (L12) | ||||
Here is one that came out of a Boston watch shop that closed in the early sixties. George Edwards NAWCC #78594 Local Chapter #76 ![]() | ||||
2nd photo George Edwards NAWCC #78594 Local Chapter #76 ![]() | ||||
