October 01, 2003, 13:20
Larry SoucheckDisplay cases
Here are two common examples. The first being a Hamilton snapback and bezel. I suspect this is how the salesman or jeweler housed the movement before the customer selected a case of his/her choice.
IHC Member 25
IHC Life Member (L6)
October 01, 2003, 13:24
Larry SoucheckThis example is made for an 18s Hampden. No bow, and hinged back and bezel. Not as common as other display cases.
IHC Member 25
October 01, 2003, 16:57
Phil DellingerLarry,
Terrific pictures as usual!!
I really like the display case with the
hinged bezel.
The only display cases that I have are the
snap-on/off bezel type, and I guess this is ok if you have a pendant set movement , but are a pain in the neck when it comes to setting the time if there is a lever set movement involved.
Phil Dellinger
NAWCC# 157070
IHC Life Member (L12)
October 01, 2003, 19:02
George R. EdwardsHere is one that came out of a Boston watch shop that closed in the early sixties.
George Edwards
NAWCC #78594
Local Chapter #76
