Mystery Tool. "Click" to Login or Register
posted April 09, 2005 10:55
I know this is some kind of warmer,but I am not sure what it was used for. I looked through an old C & E Marshall catolog and it wasn't listed there. Anyone know anything about this one?
Warmer
posted April 09, 2005 10:58
Here's a closer look. This is the closed position.
Closed
posted April 09, 2005 11:16
Here it is open.
open
Picture of Brian C.
posted April 10, 2005 05:36
Larry,
If the edges in the opening are beveled, could this be a roller table remover?
Brian C.
posted April 10, 2005 09:22
Hi Brian,
The edges of the opening are straight. What makes me think this is a warmer is that there are small amounts of shellac on the open side.the reverse side looks like it's been heated quite a few times.
posted April 10, 2005 09:35
A bluing pan for small parts?
posted April 11, 2005 16:56
I'm not sure either,but I guess it could be used for that.
Life Achievement
Military Expert
Picture of Greg Crockett
posted April 13, 2005 13:06
This is a heat-sink tool. It has various uses.
This tool would be of great use in setting pallet stones. The pallet staff sits upright in the slot which may be closed to hold it.
For some jobs, the box may be filled with fine brass filings so that it may act as a heat-sink, that is, so that it will stay warmer longer after it is removed from the flame. For some work, it is nice to keep the shellac soft long enough to permit fitting and adjustment of the stones.
Such heat sink tools are also of use for tempering small parts like balance staffs. The slow and even rise in temperature of the brass filings in the box will permit uniform tempering of small parts without burning them directly in the flame.
Best regards,
Greg
Posts: 2049 | Location: East Lansing, Michigan USA | Registered: November 24, 2002
posted April 13, 2005 18:49
Greg,
Thanks for the information on this tool. Now I know what it was used for. It also explains that container of brass filings I found.
