Page 1 2
South Bend 337 and 345 Questions and Database "Click" to Login or Register
Site Moderator
Picture of John J. Flahive III
Currently on ebay: SB Marked Grade 345, Serial number 528,281, 17 Jewels. Marked as adjusted to 3 positions. Double sunk dial.
Posts: 1755 | Location: Colorado in the USA | Registered: October 17, 2005
Picture of Keith Klimkowicz
On the Bay 337 #534851
Posts: 857 | Location: North Ridgeville, Ohio USA | Registered: November 19, 2002
Keith-
I bought the 337 off ebay since I didn't have one yet in the colection. Puts me down to 5 to go to finish the collection off and the last ones will cost me a penny or two... Here's a picture of the 337 marking so everyone can see. I didn't see any real clear pics of it on here, so thought I would share this one.
Jared
Wristwatch Host
Picture of Tony Dukes
I just purchased a SB 345 off of ebay. The serial number is 534133. It is marked 345 and adjusted.
Tony
Posts: 1953 | Location: Atlanta, Georgia in the U.S.A. | Registered: August 01, 2003
one more to add: 517075 marked 345 and Adjusted
Posts: 266 | Location: Wroclaw in Poland | Registered: May 06, 2013
Just received Grade 345 Adjusted 3 Positions
Marked 345 S/N 534612
Movement 2
Dial
IHC Member 1541
Picture of Lorne Wasylishen
Nice watch, beautiful dial.
Thanks Lorne,I am wondering if this dial could
be correct for this movement. Anybody know?
IHC Member 1541
I was pondering that but was unwilling to broach the subject.
My first thoughts based only on things that rattle about in my head is that a double sunk marginal minute dial would belong on a higher 5 position railroad watch.
I'll poke thru the South Bend catalogues and see if I can find anything.
IHC Member 1541
The 1909 South Bend catalogue (second post in this forum) mentions a double sunk dial for the 345 so you are good there.
As to whether they were using a marginal minute dial at that time I am not sure.
Montgomery Dial
First used on AT&SF in 1899 & became their approved dial in 1906.
Elgin began using it in 1910.
Illinois……………..……1911.
Hamilton………….....…1912
I got the above Montgomery dial info "somewhere on the internet" so I don't know how accurate it is.
The marginal minute dial eliminated the 6 in the seconds chapter and was supposedly a way to avoid paying royalties on the Montgomery patent so it would have come along after the Monty dial.
If someone can corroborate or refute the above, please do so.
Thanks Lorne. I was concerned about the font being in cursive instead of block form. But I did find the cursive dial here in the 1909 catalog A. It is not on a marginal dial. So as the years "jive" I believe this one to be correct.
Roger
That is one handsome pocket watch Roger. I would have picked it up for the dial alone, not even considering period correct aspects.
Rick
Posts: 535 | Location: Innisfil in Ontario, Canada | Registered: November 04, 2014
great dial and nice watch. It seems you could look for regulator arm replacement, hard to say for 100% from that picture. You could compare with grade 337 from picture above - it has proper one.
Thanks guys. You are right Rafal about the regulator arm and I am looking. Is the 337 or 345
the only ones that will work?
Roger
I found a parts movement grade 332.Looks like it has a good regulator arm and will fit on the 345. I
am unsure how to go about removing and replacing it. Any suggestions?
Roger
Hi Roger,
grade 332 is a hunter so it has part which holds hair spring on the other side, I think you would look for open face model to get that part.
Regarding removal/installation. I have the same problem, but cant find any proper info how to do it... So far I was able to remove arm without damaging it - I used razor blade which I squeezed between arm and the bridge and gently lifted up so arm jumped off its post. I did some research and it seems to be pressed fit but I didnt tried it yet. You have to be careful not to bend pins under the arm.
Rafal
IHC Member 1110
I know this is an old post, but I have marked grade 345, 528140, double sunk dial, marked adjusted to 3 positions, S.B.W.Co. in monogram.
IHC Life Member 145
Adding another 337 to the list. Recently purchased on ebay.
PWDB Link to serial 528110
Serial number is 528110 and it's marked 337.
Posts: 13 | Location: Texas in the USA | Registered: February 25, 2024
