1907 E. Howard Series 9 17J adj 3p checkerboard missing regulator pinsGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 1736 |
Hi guys, I bought this Series nine because it is in a near perfect Factory Coin Edged case... It has a great dial and super clean movement. Runs two minutes slow per day because it is free sprung with no regulator pins. Can I drift these broken bits out and replace the pins with some brass pins I trim down on my lathe? The regulator whip and bow are in great corrosion free condition... It would be a simple matter to swap the regulator whip with a spare if I had one. But since it is in such nice corrosion free condition I thought it might be nice if it is feasible to press in new pins. Thoughts or opinions? Thanks a mil, Paul'T ![]() | ||
Paul, You should be able to press out the pins (from the "bottom" side) and replace them with some new pins. | |||
