I have a watch that runs for 30 minutes or so then stops? Any idea on the problem? Advice appreciated, thanks. | ||
Is the watch in the dial up, dial down position, or doesn't matter? What maintenance/repair have you done to it lately? | ||||
Good questions, Mark. There could be so many reasons. If the watch were recently serviced and it timed properly, I'd suspect a dragging second hand. But.... if the watch was dirty and not serviced, there could be a million reasons, from dirt in the train, to a binding mainspring barrel, to bent pivots, to cracked jewels to..... ![]() | ||||
Appreciate reply, I will have it looked at. Thanks. | |||
I agree. It is all about patience and details. You might want to make sure the hair spring is level (not cocked). | ||||
Turns out the watch stem was looose and was coming out. I had it tightned and works great. Go figure, thanks for the replies. | |||
How was it coming out? | ||||
When I pulled it out to set it just pulled right out. | |||
That is strange. Did the sleve need replace? | ||||
