Watch Runs 30 Minutes-Stops???
https://ihc185.infopop.cc/eve/forums/a/tpc/f/3426047761/m/8851053702
February 07, 2006, 19:55
Mark Nathanson
I have a watch that runs for 30 minutes or so then stops? Any idea on the problem? Advice appreciated, thanks.
February 07, 2006, 21:21
Mark Estep
Is the watch in the dial up, dial down position, or doesn't matter? What maintenance/repair have you done to it lately?
February 07, 2006, 23:03
Peter S. Balkan
Good questions, Mark. There could be so many reasons. If the watch were recently serviced and it timed properly, I'd suspect a dragging second hand. But.... if the watch was dirty and not serviced, there could be a million reasons, from dirt in the train, to a binding mainspring barrel, to bent pivots, to cracked jewels to.....
Confused
February 07, 2006, 23:10
Mark Nathanson
Appreciate reply, I will have it looked at. Thanks.
February 09, 2006, 22:03
Mark Estep
I agree. It is all about patience and details. You might want to make sure the hair spring is level (not cocked).
February 13, 2006, 21:53
Mark Nathanson
Turns out the watch stem was looose and was coming out. I had it tightned and works great. Go figure, thanks for the replies.
February 14, 2006, 19:38
Mark Estep
How was it coming out?
February 14, 2006, 23:28
Mark Nathanson
When I pulled it out to set it just pulled right out.
February 16, 2006, 12:57
Mark Estep
That is strange. Did the sleve need replace?
