Watch Runs 30 Minutes-Stops??? "Click" to Login or Register
Picture of Mark Nathanson
I have a watch that runs for 30 minutes or so then stops? Any idea on the problem? Advice appreciated, thanks.
Posts: 206 | Location: Northern New York USA | Registered: January 06, 2006
Is the watch in the dial up, dial down position, or doesn't matter? What maintenance/repair have you done to it lately?
Good questions, Mark. There could be so many reasons. If the watch were recently serviced and it timed properly, I'd suspect a dragging second hand. But.... if the watch was dirty and not serviced, there could be a million reasons, from dirt in the train, to a binding mainspring barrel, to bent pivots, to cracked jewels to.....
Confused
Appreciate reply, I will have it looked at. Thanks.
I agree. It is all about patience and details. You might want to make sure the hair spring is level (not cocked).
Turns out the watch stem was looose and was coming out. I had it tightned and works great. Go figure, thanks for the replies.
How was it coming out?
When I pulled it out to set it just pulled right out.
That is strange. Did the sleve need replace?
