I am replacing a staff for an Elgin B.W. Raymond grade 478 and want to make sure I have the correct part number. Is it a 2532C Balance Staff? The roller table is a one piece double roller. The posts and research I have looked at have lead me to that, but just want to make sure. Serial number is: 30926906. Thanks. Dan
Posts: 407 | Location: Northern Virginia in the USA | Registered: October 08, 2011
a 2532 will fit and perform well. The 2532-C is a designator for the oil groove and is more correct for the BWR.
Let me know if you have trouble locating a staff. I think Mel has some. I snapped up everyone I could find this past year... which is still a pretty small stash.
I'm surprised Brian didn't say he had one available... he may be out.
Posts: 2032 | Location: San Diego, California in the USA | Registered: August 30, 2012
Tried to get a picture of the difference..The staff on the right is the "2532C"...The one on the left is the 2532...The difference is in the taper on the pivots...
Posts: 2018 | Location: Chesapeake City, Maryland in the USA | Registered: September 27, 2011
I don't think that the roller table will fit based on the way the old balance staff looks. Could it have been the wrong balance (complete) in the original?
The one I did last fall is much earlier - SN: 17337424
My parts book shows both the two piece roller and safety roller or the one piece double roller both being correct for this model. I assume they changed over but have no idea at what serial number.
Your roller should fit either staff. The shoulders are the same. And I believe, oil groove is a misnomer.... if memory serves me correctly... it's actually an oil "anti-travel" relief... to prevent oil from an over oiled pivot from traveling up the staff.
My balance is serialized to my movement.
The one I am working on did not have a serial number on the balance. Plus the balance I have looks like an Elinvar type (solid) and the balance spring is silver instead of blued. I tried a balance from a 7 jewel Elgin I had laying around and it fit pretty good ... The plot thickens...
Dan, That looks like the balance assembly, with the one piece roller, out of a 571...I would try a balance staff number 6166 (571 21 jewel staff)...A 6167 might work also if the balance was out of a lower jewel movement..
Dan, I confirmed the Factory s/n/gr#/p/n list shows Part" 2532C for your S/N movement. As I no longer have my Elgin Parts cabinets, I cannot validate the earlier pictures of the parts. But your parts picture is unmistakably for a single piece double roller.
The rather high serial number of your movement suggests that this SHOULD BE a single piece double roller but if the pictures of the 2-piece D.R. staff are this P/N, then still the fact remains you "have what you have"
In these cases, I would "match up" the correct staff to fix your watch due to the possibility that a different staff (or balance wheel assembly) was used to repair your watch in the past.
The 6167 does look closer to what is in the watch. I will look through my stuff and see if I have a 6167 laying around. Thanks everyone for the info and helping me figure this out. I will let you know how things turn out. Dan
