June 09, 2016, 19:58
Clark ReedHamilton 972 runs for hours then suddenly overbanks
I have a frustrating 16 size Hamilton 972 the 5 position 17J Hamilton that some have said is one of the best 17J watches. It is frustrating because it will run for sometimes 8 hours and keep pretty decent time being about 20-30 seconds fast in the 8 hour period, and runs in face-up and face-down positions for hours with no issue. Then, just before I gain confidence in it.... it will overbank. I have a lot of experience with 1940 Ford flathead V-8's which can also be accused of possession by spiritual forces, but I can't see them, so I can usually diagnose something that happens with some regularity and similar conditions present - - but I can't figure how to diagnose when there is nothing of substance causing the problem. I know the ultimate answer is to send it to Paul Davis - He can fix anything but a broken heart. I just want to find the guy who broke this watch's heart.....
June 13, 2016, 10:49
Clark ReedO K - I know as much as you do, and that is insufficient to diagnose much....so the watch will go to Paul Davis for his sweet stroke of genius, and he will let me know what caused the hiccups..... Thanks anyway
June 17, 2016, 14:54
Kevin HoffmanHi Clark , there are a lot of reason's for overbanking , gaurd pin bent ,too much wear in the balance pivots , to much amplitude in the balance wheel [credit to scott ceullo] and this link about it also
https://ihc185.infopop.cc/eve/f...733950587#4733950587i would look the balance over good
June 17, 2016, 22:17
Clark ReedKevin - Thank you for the info - I knew I was unqualified to fix it, but I like to know how to diagnose simpler problems just for the knowledge of the engineering of it. I appreciate your reply. I sent it to Paul Davis for examination. Thanks again !
June 22, 2016, 20:40
Paul DavisHello everyone, just for the info, I have Clarke watch up and running, two main problems caused the over banking and stoppage, first off the movement was badly gunked up which allowed it to run some but stiff, and the next problem was the pallet fork was twisted just enough to not be able to catch the roller jewel after it passed by on its return, all fixed and running great now....thanks Clark..
