Hamilton 972 runs for hours then suddenly overbanks "Click" to Login or Register
Picture of Clark Reed
I have a frustrating 16 size Hamilton 972 the 5 position 17J Hamilton that some have said is one of the best 17J watches. It is frustrating because it will run for sometimes 8 hours and keep pretty decent time being about 20-30 seconds fast in the 8 hour period, and runs in face-up and face-down positions for hours with no issue. Then, just before I gain confidence in it.... it will overbank. I have a lot of experience with 1940 Ford flathead V-8's which can also be accused of possession by spiritual forces, but I can't see them, so I can usually diagnose something that happens with some regularity and similar conditions present - - but I can't figure how to diagnose when there is nothing of substance causing the problem. I know the ultimate answer is to send it to Paul Davis - He can fix anything but a broken heart. I just want to find the guy who broke this watch's heart.....
Clark Reed
Posts: 531 | Location: Anderson, South Carolina in the USA | Registered: April 09, 2013
O K - I know as much as you do, and that is insufficient to diagnose much....so the watch will go to Paul Davis for his sweet stroke of genius, and he will let me know what caused the hiccups..... Thanks anyway
Clark Reed
Hi Clark , there are a lot of reason's for overbanking , gaurd pin bent ,too much wear in the balance pivots , to much amplitude in the balance wheel [credit to scott ceullo] and this link about it also
https://ihc185.infopop.cc/eve/f...733950587#4733950587
i would look the balance over good
Kevin - Thank you for the info - I knew I was unqualified to fix it, but I like to know how to diagnose simpler problems just for the knowledge of the engineering of it. I appreciate your reply. I sent it to Paul Davis for examination. Thanks again !
Clark Reed
Picture of Paul Davis
Hello everyone, just for the info, I have Clarke watch up and running, two main problems caused the over banking and stoppage, first off the movement was badly gunked up which allowed it to run some but stiff, and the next problem was the pallet fork was twisted just enough to not be able to catch the roller jewel after it passed by on its return, all fixed and running great now....thanks Clark..
Paul Davis
Posts: 672 | Location: Missouri in the USA | Registered: May 01, 2015
