what type winding stem do i use "Click" to Login or Register
IHC Member 376
Watchmaker
Picture of Samie L. Smith
posted December 26, 2004 16:15
I have some wristwatch,s that have a 0 size movements in them I am attaching a picture of 2 of them...My question is what type of stem setup did these use there is no threads in the case to put a pocket watch style sleeve in..
Pictures would be of a great help to me...
the watch on the left is a waltham and the other is a ideal watch co.
IHC Member 376
Watchmaker
posted December 26, 2004 16:17
edge of the waltham movement..
IHC Member 376
Watchmaker
posted December 26, 2004 16:19
shot of the winding setup under the dial on the waltham ..
Picture of Jerry Treiman
posted December 26, 2004 16:37
These take a short inverted sleeve that slips in from the inside of the case ring. There are no threads. I will post a picture later this evening if no one else has had a chance.
IHC Member 376
Watchmaker
posted December 26, 2004 19:26
Thanks Jerry looking foward to seeing the pictures..I have quite a few parts and may have the right stem..
posted December 26, 2004 19:46
Jerry, I have several cases with that setup and never knew exactly what it was called. Thanks. Now I know it is an inverted sleeve.
posted December 26, 2004 23:04
Here is a photo that I hope adequately illustrates the setup. The flange on one end of the sleeve fits in a recess in the case ring. When the movement is in place it is held so that the stem can click in and out. Tom - the term "inverted sleeve" is my own but seemed to describe the sleeve. Now that I look in my Waltham material catalog I see that Waltham, at least, called it a "reverse sleeve"
posted December 26, 2004 23:05
Here is a picture of everything assembled.
Picture of Brian C.
posted December 27, 2004 05:25
Great pictures Jerry.
There are also pictures of stems and sleeves in the Swigart's American Watch Movements catalog, (in the back).
Brian C.
IHC Member 376
Watchmaker
posted December 27, 2004 09:29
THANKS JERRY FOR THE GREAT PICTURES ,,I will look through the parts i have and se if i have the right parts....
Are the parts something that can still be bought ..
Smile
posted December 27, 2004 20:33
Jerry, I'll call it an inverted sleeve and give you credit for it.
Sammie, Jerry mentioned this above, but be sure that the movement is in the case for this type of setup to work proberly.
