Is this tool worth it?
https://ihc185.infopop.cc/eve/forums/a/tpc/f/3426047761/m/7173930877
April 13, 2013, 00:59
Peter Levy
I wanted to get some opinions or suggestions for my new problem. I am working on my infamous Montblanc Timewalker and the minute hand keeps coming loose. Bergeon sells a tool called a tube tightener. It's only $589.00! Cheap huh?
Is there something that you guys might use that will be a little more cost effective? Normally I would just change the hand to a new one, unfortunately Montblanc does not sell parts to "unauthorized" dealers.
April 13, 2013, 01:02
Evan Patton
Staking set?
April 13, 2013, 01:11
Peter Levy
I was worried a staking set may crush the tube. I would rather get one of those instead of a tool that I might only use a couple times.
April 13, 2013, 08:07
Gary E. Foster
A staking set will handle this, just proceed with care.
April 13, 2013, 10:28
Peter Levy
Then a staking set it is.
April 13, 2013, 14:29
Michael Briggs
Does the minute hand have a tube, as second hands typically do? If it doesn't this tool probably wouldn't help. If it has a tube, another technique I've read about is to squeeze it in a collet in a lathe.
April 13, 2013, 16:35
Peter Clare
Or a pin vise..
Peter
April 14, 2013, 10:36
Brian C.
If you use a pin vice on the second hand tube, put a broach through the tube so you don't close the tube too much.
April 16, 2013, 20:48
Peter Levy
You're right it doesn't have a tube. My bad. Any other suggestions. New minute wheel?
April 18, 2013, 20:21
Gary E. Foster
Peter, if you have access to The Watch Repairers Manual, by Henry B. Fried, he describes how to reduce the size of the holes in hands in chapter 3.
Gary
April 18, 2013, 20:49
Gary E. Foster
Peter, check out John Duvalls Helping Hand tutorials, there is a section on fitting hands you may find helpful:
Fitting & Installation of Pocket Watch Hands
April 21, 2013, 01:30
Peter Levy
That was very informative. Thank you.
May 21, 2013, 16:11
Patrick Wallin
Gorilla Glue
