Removing Hair Spring "Click" to Login or Register
I find it hard to get a pair of levers on the collet without bending or breaking off the hairSpring to remove it.
I am ready to resign mySelf to use of a staking set. It seems those tools aren’t good or need to be modified.
Any favorite or best known methods to choose?
Posts: 144 | Location: New York in the USA | Registered: September 23, 2018
Picture of Brian C.
James, e-mail me I might be able to help you.
Hi James , do you have a picture of what your using ? Here are the tools I like , the first is a fork I think from KD they make a small and large , get the small , the other is a collet adjuster made from an old mainspring , if you place the balance in a v block the roller table hold it still , careful of the jewel , it should point towards you, rotate the collet while inserting and gently lifting
homemade collet adjuster, Daves watch parts had some other tools , including pliers- does anyone use the pliers ? http://www.daveswatchparts.com/HairspringTools.html
China red and blue handle on ebay.
I think I will try to thin them down on a stone.
They dont get under the collet very good.
They just end up sliding up the brass and bend the spring without extra ordinary care. Just a bit blunt.
Do You rotate with the one tool and lift with the forked KD tool ?
actually I just slip it under the collet , I was shown to do both but the tool works really good , I have a set similar to what you have , and also damaged a few , I thought maybe they are too thick ?. I was really curious about the pliers also .
