Seconds hand loose "Click" to Login or Register
Picture of Bruce Byrd
Hi all,
What is the best way to tighten up a loose seconds hand (Hamilton 992e). I bought one from Larry, but it's a bit loose on the pinion. Any ideas without buying an expensive tool?
I do have a staking set...if that helps my plight..
Bruce Byrd
IHC Member 1613
Bruce,
I take it and fit it into a lathe collet that fits tight on the center post then put it in the lathe and tighten the collet up a litle. There are probably better ways but this works seems to work for me..Just make sure you have a small broch in case you close it a little too much..
Posts: 2025 | Location: Chesapeake City, Maryland in the USA | Registered: September 27, 2011
Picture of Brian C.
You can also use a pinvice.
