October 06, 2012, 17:42
Bruce ByrdSeconds hand loose
Hi all,
What is the best way to tighten up a loose seconds hand (Hamilton 992e). I bought one from Larry, but it's a bit loose on the pinion. Any ideas without buying an expensive tool?
I do have a staking set...if that helps my plight..
October 06, 2012, 19:03
Gary E. CochranBruce,
I take it and fit it into a lathe collet that fits tight on the center post then put it in the lathe and tighten the collet up a litle. There are probably better ways but this works seems to work for me..Just make sure you have a small broch in case you close it a little too much..
October 07, 2012, 11:19
Brian C.You can also use a pinvice.
