Loose Dial problemGo ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
Good evening: I have a Model 88 16s Waltham with a loose dial. The holes on the plate that the feet of the dial go into are offset with the tightening screws on the edge. When I tighten the screws there seems to be no effect on the dial, i.e. it just falls off. On an 1883 model that I have, the edge screws are lined up to the center of the dial feet holes, and therefore when the screws are tightened it directly contacts the feet and holds the dial in place. Is it possible that a catch is to pivot out when the screws are tightened on this 88 model? Does anyone have any suggestions? Thank you! Grant Perry NAWCC #0157065 Chapter 111 IHC-185 #141 | |||
The 88's (and 16S 99's) that I have seen have dial screws very slightly to one side of the center on the dial feet. The dial screws should enter slightly offset and perpendicular to the dial foot hole and secure the dial. When it doesn't happen, it could mean that A)The dial feet are worn. B) New dial screws have been installed, or C) a replacement dial, with smaller dial feet, has been put on the watch. I'm not quite sure of a fix, other than trying diffeternt dial screws. Mike Miller NAWCC Member# 154831 NAWCC-IHC Charter Member# 27 | ||||
Grant, If the dial feet are too small in diameter, you may want to build up their width. You could try sleeving them or using some heat-shrink tubing like they use for electrical splicing on aircraft. Most electrical supply houses should have it. Find a piece that will just slip over the dial foot, trim it so that about about 2 mm's extend beyond the dial foot. They make special heating guns but you can try heating with a hair dryer set on high. The tubing should shrink and harden very tightly around the dial foot. Cut off any excess length. This repair is reversible by removing the tubing with an Exacto or razor blade. Just a thought....... John D. Duvall Rosamond, CA. NAWCC Member 0144772 NAWCC IHC Member 192 | |||
Mike/John: Thank you for the tips! Mike, I think you may be right. The dial seems to have excess shake when compare to other dials that I have worked with. I think the dial is probably not original to the movement. I think I will try the shrink tube or a replacement dial. Thanks guys. Grant Perry NAWCC #0157065 Chapter 111 IHC-185 #141 | ||||
