This is a two piece arbor threaded together in the middle. Install ratchet wheel on arbor, Hold barrel between fingers, Unscrew arbor by turning ratchet wheel. Right hand thread. Lower half will begin to float, unscrew it fully.
Posts: 209 | Location: Colorado Springs, Colorado in the USA | Registered: April 23, 2013
Tom, I have found the safest means of unscrewing the two-piece motor barrel arbor assembly is to re-assemble the large winding wheel ("F") to the barrel arbor, that gives you a "hand" on one end of the arbor assembly. Then grip the barrel itself (with a soft clamp) and you should be able to "break loose" the threaded arbor assembly.
