IHC Life Member![]() |
Anyone know how to reset the watch after changing the battery? I have a Kenneth Cole Reaction on the case back it has U54-02 RK5027. Last week the analog part was working but the digital was not. I put in a new battery, now the digital is working but the analog is not. Any ideas? I can't find anything marked AC to cross with the battery which is how many digital watches are reset. ![]() ![]() Roddy JB | ||
IHC Life Member Certified Watchmaker ![]() |
Hi Chris, You were right of course. However, not being a watchmaker, when I went to reassemble the watch after changing the 2nd battery, I noticed 2 little springs & a 'clip' of some sort had come out & I have no idea where they go. I guess I should have left it alone. I guess now I'll put all the bits into a small baggie. Rod Roddy JB | |||
Put it the project draw you can always go back to it another day now its near fixed ![]() if you have photos of the parts and the upper board removed we maybe able to figure where they go, I can see one spring in your photo is that one? | |||
here is 1st pic Roddy JB | |||
2nd Roddy JB | |||
3rd Roddy JB | |||
Hi Chris, Don't know if these pics will help or not. Regards, Rod Roddy JB | |||
I think I worked out where they went... Roddy JB | |||
got the springs back in & the clip, it went in the main battery opening. put in the 2 new batteries. And now nothing works? Now I do give up! Roddy JB | |||
Take the circuit off and see if the analogue works on its own. you may have not aligned to circuit spot on to make contacts with the black strips. I take it springs re photo 1 at 1 & 7, and clip in round recess in white plastic small tab uppermost | |||
Hi Chris, That didn't seem to do it either, now nothing seems to work. First one worked then I changed a battery & the one started working but the first one quit. Changed the second battery now nothing works, I just don't get it. Rod Roddy JB | |||
