Watch w/a Consistent Stopping Point...Go ![]() | New Topic ![]() | Find-Or-Search ![]() | Notify ![]() | Tools ![]() | Reply to Post ![]() | |
| IHC Member 234 |
...to what can one attribute the cause of a watch whose sweep hand runs then stops at the same position on the chapter ring...watch will then resume running when the hands are reset...I'm referring to a Bulova (caravelle) quartz movement in this case...thanks...Jim C | ||
Jim, Is it possible that the arbor for the center seconds hand is bent? That would be all I could think of off hand. What we need is some sort of expert here. Aaron | ||||
It may be simply that the second hand is touching the dial at that spot. If not,problem somewhere in the train in the arbor/teeth/pinion of the second hand gearing. Sam Williamson NAWCC 154312 IHC Charter Member 14 Member Chapters 96 and 185 | ||||
| Watch Repair Expert |
It's probably a small speck of debris stuck between a couple of wheel teeth. Every time the wheel rotates to the same place, the pinion it turns locks up on the debris. I've only seen that happen about 10,000 times, in virtually every type of watch. ================== Steve Maddox President, NAWCC Chapter #62 North Little Rock, Arkansas IHC Charter Member 49 | |||
| IHC Member 234 |
...much appreciate your advice...will initiate and report...thanks!...Jim C | |||
| IHC Member 234 |
...well the watch went back to it's owner (a neighbour) correct twice a day...I checked the hands and their clearance and all appeared to be fine...got down to pulling out the printed circuit board on my way to the wheels and pinions and decided that this exercise was well beyond my level of skill/knowledge and buttoned it back up...it went back to my neighbour 'buttons and bows' intact (as well as a new battery...:0) | |||
Probably the best thing for it. Back to the neighbor. Aaron | ||||
